Author Topic: How do I combine these  (Read 1620 times)
Biscuits
« on: July 02, 2015, 11:23:50 AM »
Hello everyone...hopin' to get a little help from my friends.
In the following code each of the first three lines of code work fine to acquire an attribute for modifying.
I need to comment out two of the three for the routine they reside in to work.
I'm constantly changing the  ":" to accommodate the situation.
Hope I'm making sense here.
The last line of code is my attempt to combine the first three into one. But, no go.
Any ideas?
Thanks in advance
(if (= (cdr (assoc 1 (entget ename))) "---")
:(if (= (cdr (assoc 1 (entget ename))) "MM/DD/YY")
:(if (= (cdr (assoc 1 (entget ename))) "XX/XX/XX")
(if (= (cdr (assoc 1 (entget ename))) "---" "MM/DD/YY" "XX/XX/XX")
Re: How do I combine these
« Reply #1 on: July 02, 2015, 11:43:47 AM »
or?
(if (or (= (cdr (assoc 1 (entget ename))) "---")
;;; do stuff here
Biscuits
« Reply #2 on: July 02, 2015, 11:53:24 AM »
OMG....I have vapor-lock on the brain these days!
Works perfectly!
Thank you, Keith..............drinks on me!
« Reply #3 on: July 02, 2015, 12:38:00 PM »
And another :
(if (vl-position  (cdr (assoc 1 (entget ename))) '("---" "MM/DD/YY" "XX/XX/XX"))
;;; do stuff here
« Reply #4 on: July 02, 2015, 12:55:06 PM »
One more:
  1. (if (wcmatch (cdr (assoc 1 (entget ename))) "---,MM/DD/YY,XX/XX/XX"))
  2.     ;;; do stuff here
  3. )
Biscuits
« Reply #5 on: July 02, 2015, 01:47:14 PM »
Thanks for the replies, gang!
Obviously more than one way to skin the kat!
