Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
perpect scale fit lisp?
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: perpect scale fit lisp? (Read 1259 times)
dussla
Bull Frog
on:
July 02, 2015, 12:24:10 AM »
hello firends
always my many ask ,really thank you
i meet problems always
if you see attach file , you can see 2 block
if you see that 2 block , that size is little diffirent
i would like to make perpect same
how can i make scale lisp for that ?
Logged
trogg
Bull Frog
WWW
Re: perpect scale fit lisp?
Reply #1 on:
July 02, 2015, 01:04:07 AM »
This doesn't need a lisp routine to fix. you have 4 blocks and it looks like one (the green one) is the correct size. So open the green block in the block editor and then use the command BLOCKSAVEAS and then name it the same name of the block that you want to redefine. It will then prompt you that you are about to redefine the block in the drawing. Then repeat for the other other blocks.
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
