I have a reactor running that logs the file name and time when I save my drawing (I use the log as a reminder of what I worked on when I do my time sheet). However, if I'm in the block editor I would like it to include the name of the block.
How can I tell if the block editor is active?
I thought I might check to see if the "Block Editor" ribbon tab was showing on the ribbon, but it looks like it takes .NET to do that.
I wondered about checking the window caption, but that doesn't change in the block editor.
Suggestions appreciated.
