Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Modelling error - snub dodecahedron modeling
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Modelling error - snub dodecahedron modeling (Read 1428 times)
ribarm
Gator
Marko Ribar, architect
WWW
on:
June 30, 2015, 07:23:14 AM »
Here is situation... If you have 20+ minutes, please watch this video :
https://www.youtube.com/watch?v=hOO-y1R3HgU
It shows my geometric construction of pretty difficult POLYHEDRON called SNUB DODECAHEDRON... This construction is the most closest to exact precise solution and I don't know any better... (If you know please help me - it's not a task but only pleasure to make us more wise and smart...) ... Anyway, after watching this video, near its ending I tried both UNION command and SURFSCULPT command on bounding REGIONS but I failed to obtain unique 3DSOLID entity... As addition to this post, I'll attach this version of MODEL - constructed with shown geometry procedure to save you time and I'll post a code for scaling regions by their centroid points - I thought this will make model watertight, but I was wrong... So my question : Is after all possible to construct this MODEL as 3DSOLID entity using this geometry concept? If you know any better solution for constructing starting rotation angle of first edge adjacent triangle pyramid, but without math result (knowing ratio of Radius of sphere of snub dodecahedron and one its edge - you can google this), please give us that info...
Here is the code and attachment DWG :
Code - Auto/Visual Lisp:
[Select]
defun
c:scaleregsbycentroids
*error*
adoc
v
v unit ucs ucsf ss scf i reg n x y p ce
vl-load-com
defun
*error*
msg
while
not
eq
getvar
'worlducs
1
command
"_.UCS"
"_P"
if
ucsf
command
"_.UCS"
"_P"
vla-endundomark
adoc
if
msg
prompt
msg
princ
defun
v
v
u v
mapcar
lambda
s1 s2 a b
eval
s1
nth
a u
nth
b v
eval
s2
nth
a v
nth
b u
1
0
0
2
2
1
defun
unit
v
mapcar
lambda
x
x
distance
0.0
0.0
0.0
v
v
setq
adoc
vla-get-activedocument
vlax-get-acad-object
vla-startundomark
adoc
if
eq
getvar
'worlducs
0
progn
command
"_.UCS"
"_W"
setq
ucsf t
prompt
\n
Select regions for scale by their cetroids"
setq
ss
ssget
"_:L"
0
"REGION"
initget
6
setq
scf
getdist
\n
Pick or specify scale factor <1.1> : "
if
null
scf
setq
scf
1.1
if
ss
repeat
setq
i
sslength
ss
setq
reg
ssname
ss
setq
i
1-
i
setq
n
vlax
safearray
list
vlax
variant-value
vla-get-normal
vlax
ename
vla-object
reg
if
equal
v
v n '
0.0
0.0
1.0
0.0
0.0
0.0
1e
6
setq
x '
1.0
0.0
0.0
y '
0.0
1.0
0.0
setq
x
unit
v
v n '
0.0
0.0
1.0
y
unit
v
v n x
command
"_.explode"
reg
while
getvar
'cmdactive
0
command
setq
p
vlax-curve-getstartpoint
entlast
command
"_.undo"
while
getvar
'cmdactive
0
command
setq
ucs
vla-add
vla-get-usercoordinatesystems
adoc
vlax-3d-point
p
vlax-3d-point
mapcar
p x
vlax-3d-point
mapcar
p y
"{ UCS }"
vla-put-activeucs
adoc
ucs
command
"_.UCS"
"_D"
"{ UCS }"
vlax-release-object
ucs
setq
ce
trans
vlax
safearray
list
vlax
variant-value
vla-get-centroid
vlax
ename
vla-object
reg
1
0
while
not
eq
getvar
'worlducs
1
command
"_.UCS"
"_P"
command
"_.SCALE"
reg
"_non"
ce scf
while
getvar
'cmdactive
0
command
*error*
nil
defun
c:scregs
cent
nil
Thanks for reading and watching video, M.R.
Last Edit: July 30, 2015, 01:40:37 PM by ribarm
Logged
Marko Ribar, d.i.a.
(graduated engineer of architecture)
M.R. on Youtube
ribarm
Gator
WWW
Re: Modelling error - snub dodecahedron modeling
Reply #1 on:
July 02, 2015, 01:44:34 AM »
To obtain real 3DSOLID entity, you'll have to be even more precise... So you'll have to scale RED CIRCLE by factor : 0.999966385 (it's easy to remember at least for me...)
M.R.
Logged
Marko Ribar, d.i.a.
M.R. on Youtube
ribarm
Gator
WWW
Reply #2 on:
July 03, 2015, 01:36:49 PM »
The same issue with SNUB CUBOCTAHEDRON...
VIDEO :
https://youtu.be/Hw-zp-80lkw
To obtain real 3DSOLID entity, you'll have to be even more precise... So you'll have to scale RED CIRCLE by factor : 1.000180852
M.R.
Logged
Marko Ribar, d.i.a.
M.R. on Youtube
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
