Author Topic: Draw a tube ,need help.  (Read 7118 times)
Re: Draw a tube ,need help.
« Reply #15 on: June 30, 2015, 07:30:43 AM »
AIberto,
Welcome to the Swamp.
Would this task be a homework assignment?
Alan
« Reply #16 on: June 30, 2015, 10:07:11 AM »
<snip>
Tim, I test your code ,  Z axis  have flaw.  see demo
I think the issue is that the distance calculated is always positive, and based on the pick point order it should be negative.  I guess one could see which way the vector variable 'vec' is pointing, and tell the distance to be positive or negative.
Or you can just use the path option, and it will extrude it along the whole path.
Or you can just leave out the last part of the command, and let it be open ended so the user can select the end point of the extrusion.
Or... (I am sure there are more options)
AIberto
« Reply #17 on: June 30, 2015, 11:14:10 AM »
I would use path option of extrude like Tim suggested...
Hi marko , Thanks you for you help. It's nice .
AIberto
« Reply #18 on: June 30, 2015, 11:19:50 AM »
AIberto,
Alan
Dear Alan
pleasure to meet you. Not a homework , This is a practice.
AIberto
« Reply #19 on: June 30, 2015, 11:22:56 AM »
<snip>
Thanks Tim
Marko has helped me . now It's ok !
  1. ; http://www.theswamp.org/index.php?topic=49677.0
  2. (defun c:tube(/ )
  3.    (if (setq pt (getpoint "\n Specify base point: "))
  4.         (progn
  5.         (setq pt2 (getpoint pt "\nSpecify the directio: "))
  6.         (if (null #ra1) (setq #ra1 5.0))
  7.         (if (null #ra2) (setq #ra2 8.0))
  8.         (if (null #len) (setq #len 20.0))
  9.         (setq rad (getdist(strcat "\nEnter inner diameter: <" (rtos #ra1) "> ")))
  10.         (if (= rad nil)(setq rad #ra1))
  11.         (setq #ra1 rad)
  12.         (initget "T")
  13.         (setq otr (getdist (strcat "\nEnter Outer diameter OR [Thickness (T)]: <" (rtos #ra2) "> ")))
  14.         (if (member otr (list "t" "T"))
  15.         (if (setq tck (getreal (strcat "\nEnter Thickness: <" (rtos (- #ra2 #ra1)) "> ")))
  16.         (setq otr (+ rad tck))(setq otr (+ rad (- #ra2 #ra1))))
  17.         (if(= otr nil)(setq otr #ra2 )))
  18.         (setq #ra2 otr)
  19.         (setq len (getdist(strcat "\nEnter length: <" (rtos #len) "> ")))
  20.         (if(= len nil)(setq len #len))
  21.         (setq #len len)
  22.         (setq vec (mapcar (function -) pt2 pt))
  23.         (entmake
  24.                 (list
  25.                         '(0 . "LINE")
  26.                         (cons 10 (trans pt 1 0))
  27.                         (cons 11 (mapcar '+ (trans pt 1 0) (mapcar '* (mapcar '/ vec (list (distance pt pt2) (distance pt pt2) (distance pt pt2))) (list len len len))))
  28.                 )
  29.         )
  30.         (setq path (entlast))
  31.         (entmake
  32.                 (list
  33.                         '(0 . "CIRCLE")
  34.                         '(100 . "AcDbEntity")
  35.                         '(100 . "AcDbCircle")
  36.                         (cons 10 (trans pt 1 vec))
  37.                         (cons 40 (* rad 0.5))
  38.                         (cons 210 vec)
  39.                 )
  40.         )
  41.         (setq ent1 (entlast))
  42.         (command "_region" ent1 "")
  43.         (setq ss1 (entlast))
  44.         (entmake
  45.                 (list
  46.                         '(0 . "CIRCLE")
  47.                         '(100 . "AcDbEntity")
  48.                         '(100 . "AcDbCircle")
  49.                         (cons 10 (trans pt 1 vec))
  50.                         (cons 40 (* otr 0.5))
  51.                         (cons 210 vec)
  52.                 )
  53.         )
  54.         (setq ent2 (entlast))
  55.         (command "_region" ent2 "")
  56.         (setq ss2 (entlast))
  57.         (command "_subtract" ss2 "" ss1 "")
  58.         (command "_extrude" (entlast) "" "_P" path)
  59.         (entdel path)
  60.         )
  61.         )
  62.   (princ)
  63. )
  64.
AIberto
« Reply #20 on: June 30, 2015, 12:37:04 PM »
Hi, if you still want to use your old code you can simply specify positive/negative length to change Z direction up/down and replace
(command "_.Rotate3d" "_l" "" "_X" @pto 90)
with
(command "_.Rotate3d" "_l" "" "_X" @pto 270)
for draw tube like "positive=up", "negative=down".
Thanks Nick,
I think this is not best.  specified the direction already , so no need options
AIberto
« Reply #21 on: June 30, 2015, 12:47:02 PM »
The code at  #19, a little defect.
The  value of Outer diameter must  Greater than(> ) inner diameter
  1. (setq tf t)
  2. (while tf
  3.   (initget "T")
  4.   (setq otr (getdist (strcat "\nEnter Outer diameter OR [Thickness (T)]: <" (rtos #ra2) "> ")))
  5.   (if (member otr (list "t" "T"))
  6.     (progn (if (setq tck (getreal (strcat "\nEnter Thickness: <" (rtos (- #ra2 #ra1)) "> ")))
  7.              (setq otr (+ rad tck))
  8.              (setq otr (+ rad (- #ra2 #ra1)))
  9.            )
  10.            (setq tf nil)
  11.     )
  12.     (progn
  13.       (if (= otr nil)
  14.         (setq otr #ra2)
  15.       )
  16.       (if (<= #ra2 #ra1)
  17.         (princ "\nID Greater than OD,Please Enter again!")
  18.         (setq tf nil)
  19.       )
  20.     )
  21.   )
  22. )
  23.
« Last Edit: June 30, 2015, 08:50:34 PM by AIberto »
ribarm
  • Marko Ribar, architect
« Reply #22 on: June 30, 2015, 01:27:27 PM »
Alberto, I've modified my code :
this :
  1. (cons 11 (mapcar '+ (trans pt 1 0) (mapcar '* (mapcar '/ vec (list (distance pt pt2) (distance pt pt2) (distance pt pt2))) (list len len len))))
  2.
should be :
  1. (cons 11 (trans (mapcar '+ pt (mapcar '* (mapcar '/ vec (list (distance pt pt2) (distance pt pt2) (distance pt pt2))) (list len len len))) 1 0))
  2.
M.R. on Youtube
AIberto
« Reply #23 on: June 30, 2015, 08:52:56 PM »
this :
  2.
should be :
  2.
Hi marko .Thank you ! gooooood!
