Author Topic: Help help!!  (Read 6286 times)
Re: Help help!!
« Reply #15 on: June 24, 2015, 11:26:37 AM »
Second, drawing tracking systems usually track by filename not by drawing; with a 1:1 relationship between file and drawing it minimizes management and storage issues.
I have one .dwg with 20 layouts. If i used their method i would have 20 .dwg's. How does that minimize management and storage?
It's an antiquated way of doing things and IMO generally has little value ... I usually keep my working drawing with multiple tabs, then when I submit to the client break them out individually using this.
Rob...
Re: Help help!!
« Reply #16 on: June 24, 2015, 11:28:37 AM »
single-layout drawings have been SOP since well before my time
Like I said, "Old School". I do not have entire projects in one file, but for example all details sheets are in one file per trade. Floor plans that do not fit on one sheet are divided into multiple layouts, one file/floor/trade.
CAD Tech
Re: Help help!!
« Reply #17 on: June 24, 2015, 11:40:13 AM »
Working in a team environment is impossible when one user has the entire project locked up to work on one 'sheet' at a time, so single-layout drawings have been SOP since well before my time
I can agree with you there! For us though, its one person on drawing.
Re: Help help!!
« Reply #18 on: June 24, 2015, 11:42:42 AM »
Succinctly:
1. Every client wants 1:1 relationship between hard copy and dwg file.
2. Multiple designers.
Re: Help help!!
« Reply #19 on: June 24, 2015, 11:46:53 AM »
Yes, because Civil 3D actually likes it that way...because so much of the labels are directly connected to the model.
BlackBox
Re: Help help!!
« Reply #20 on: June 24, 2015, 11:55:39 AM »
You forget that I have so little experience - well before my time is not the same as well before yours, or others'. :angel:
Oddly enough, multi-layout drawings was the norm back then, and this single-layout SOP was a break from "old school" thinking (to those who taught me anyway, YMMV). :-D
That aside, to-date there is no simpler, more consistent, and flexible way to both manage a project (small or large), and allow for on-demand team resource allocation when a given deadline requires it.
Cheers
Rob...
Re: Help help!!
« Reply #21 on: June 24, 2015, 01:00:38 PM »
There is no way that this would work for our working files. It would be over complicating some very simple tasks. Running piping or ductwork between files just because the entire floor doesn't fit on one sheet would be a huge waste of time and prone to errors.
CAD Tech
Re: Help help!!
« Reply #22 on: June 24, 2015, 01:07:55 PM »
Our "plot" drawings are separate from our design files, so having multiple people work on a project is a non-issue.
BlackBox
Re: Help help!!
« Reply #23 on: June 24, 2015, 01:24:55 PM »
Wait... You put your design elements in the actual sheets? :?
I 'spose that does complicate a relatively simple task.
For clarity, we differentiate between drawings that plot (i.e., exhibits, sheets, etc.), and those that do not (i.e., models containing line work, and C3D Objects for DREF/XREF only).
We generally have one existing, and proposed model (for each phase, if needed), and those are XREFed into said 'sheets', so the only entities within that sheet itself are labels, annotations, dimensions, etc. (in model), and the attributed title block (populated with Fields via SSM Properties) & Viewport(s) (in layout).
As example, team production breakout, would have one user modify the proposed model, and one or more update the 'sheets', etc.
Re: Help help!!
« Reply #24 on: June 24, 2015, 01:32:13 PM »
You're doing it right.
Rob...
Re: Help help!!
« Reply #25 on: June 24, 2015, 01:35:05 PM »
Wait... You put your design elements in the actual sheets [files]? :?
Complication is a matter of perspective. I'd much rather have sheet files containing just title blocks, annotation would still be done in the models, but not everyone here is familiar with that methodology. Every time I need to use sheet files, someone messes up the works somehow.
CAD Tech
Bethrine
Re: Help help!!
« Reply #26 on: June 24, 2015, 01:53:49 PM »
Maybe this doesn't apply, but, when I was reading up on sheet sets, it stated in the documentation that multiple layouts in a single drawing caused problems with them. I don't remember why, I just remember reading it somewhere.
Re: Help help!!
« Reply #27 on: June 24, 2015, 02:01:17 PM »
As with complication being a matter of perspective so is right and wrong. As long as you and your employees can navigate effectively and efficiently, the current methods conform to your workflow standards (do not hinder the design/QA philosophy), and you can meet the client needs with as little overhead as possible then you can not consider one method better. Set up your standards to mirror your workflow/company.
Making a decision (even if it is deemed "not as effective as" later) is better then atrophy.
Daniel J. Ellis
Re: Help help!!
« Reply #28 on: June 25, 2015, 04:02:06 AM »
Amen.
FWIW My firm do Planning Application for volume housebuilders in the UK and this is how we set up our files:
We produce two types of drawings - Layout-based and Housetypes.  The Layout-based drawings deal with some aspect of the site layout, Hosuetypes with the individual buildings.
Layout-based drawings derive from a number of XREFS.  Details will vary from project to project but generally would be the X-Layout (the bulk of our proposals), a survey, and OSMap, and civil engineering for slab and road levels, plus any additional context data (offsite road works, adjacent developments, etc.).  We then have a separate file for each drawing (Planning Layout, External Works, Vehicle Tracking, Adoption, etc.) which will have separate layout tabs if that drawing needs to extend across several sheets (this is often the case with the External Works, for example).
Housetypes will have a separate file per housetype (2B4P or 3B5P, for example) but plans/elevations and all varns (brick/render, side windows) will all be in that file on different layout tabs for their sheets.
dJE
dJE
