Author Topic: Block insertion point..  (Read 4374 times)
Rod
Re: Block insertion point..
« Reply #15 on: June 29, 2015, 11:39:25 PM »
Occurs regardless of the point in space (as long as insertion point "specify on screen" is not checked)
Occurs whether you have scale or rotation or both set to "specify on screen".
Doesn't occur when explode is checked (but there is no ghost/jig)
Funny that the rubber band comes from the correct insertion point.
"All models are wrong, some models are useful" - George Box
huiz
  • Certified Prof C3D
« Reply #16 on: June 30, 2015, 04:35:16 AM »
In 2014 it works as expected, in 2016 it is not. Weird bug...
« Reply #17 on: June 30, 2015, 06:42:34 AM »
Andrea,
Have you reported this to AutoDesk ?
