Author Topic: Block insertion point..  (Read 4529 times)
Andrea
« on: June 23, 2015, 12:43:20 PM »
I think this is an autoCAD issue..
Hi all,..
a friend show me a strange result with block insertion..
there it is..
1) use "insert" command and select any block.
2) uncheck the "Insertion Point" and "Scale" option...but keep the "Rotation" Checked. (see image)
3) Insert your block and see the result.
Insertion coordinate will take the cursor position instead of specified coordinates points.
I think that weird result is an issue.
(tested on 2015 and 2016)
INSBASE and BASE set to 0,0,0
so I just need to know if any of you have same result..
thank you. :)
« Last Edit: June 23, 2015, 12:49:07 PM by Andrea »
Keep smile...
Rob...
Re: Block insertion point..
« Reply #1 on: June 23, 2015, 01:05:32 PM »
Does this happen with any block? I tried it in 2014 and it works as expected.
Could it be that the "basepoint" assigned in the block is not at (0,0)?
CAD Tech
« Reply #2 on: June 23, 2015, 01:09:14 PM »
check base point of block definition...if NOT 0,0
Fix it with block editor
Hugo
« Reply #3 on: June 23, 2015, 01:10:23 PM »
Ja hier auch das Problem
Rob...
« Reply #4 on: June 23, 2015, 01:11:14 PM »
Thanks for clearing that up.
CAD Tech
Andrea
« Reply #5 on: June 23, 2015, 01:20:38 PM »
nope...
Block units is unitless, insertion point is good..INSUNITS, DEFSOURCE and DEFTARGET are ok...
INSBSE and BASE variable also..0,0,0.
eaven if the coordinate is not 0,0,0...the issue still.
Hugo seem to have same issue,
If you unselect the Rotation...all work great.
see animated gif below..
« Last Edit: June 23, 2015, 01:25:14 PM by Andrea »
Keep smile...
Rob...
« Reply #6 on: June 23, 2015, 01:23:17 PM »
That is odd. Looks like a bug.
CAD Tech
« Reply #7 on: June 23, 2015, 01:26:19 PM »
that the rotation snaps to 0,0 and not insert (base) point of the block seems to indicate to me that the block definition is poor.
Make a NEW block being sure to define a GOOD base point....and try again
Andrea
« Reply #8 on: June 23, 2015, 01:29:36 PM »
Nope...
Bug is real...
tested with new block,..the problem occur in 2015 and 2016 only..
Keep smile...
« Reply #9 on: June 23, 2015, 01:34:03 PM »
Confirmed in 2015 - looks to be a bug.
Andrea
« Reply #10 on: June 23, 2015, 01:49:23 PM »
thank you to confirm. :)
Keep smile...
« Reply #11 on: June 23, 2015, 02:13:16 PM »
AMAZING!
After all these years Autodesk BROKE the Block Insert Command!  Awesome results for your subscription 'investment' in their product development efforts!
« Reply #12 on: June 23, 2015, 03:03:48 PM »
AMAZING!
Start your blog already .. looks like http://ihateautodesk.com/ is available.
Matt__W
  • I like my water diluted.
« Reply #13 on: June 23, 2015, 04:05:58 PM »
nope...
It's placing the block at the location of the cursor prior to starting the block command.
Autodesk Expert Elite
Daniel J. Ellis
« Reply #14 on: June 24, 2015, 08:19:14 AM »
Do you have dynamic input turned on?
Does this affect its behaviour?
dJE
dJE
