I think this is an autoCAD issue..
Hi all,..
a friend show me a strange result with block insertion..
there it is..
1) use "insert" command and select any block.
2) uncheck the "Insertion Point" and "Scale" option...but keep the "Rotation" Checked. (see image)
3) Insert your block and see the result.
Insertion coordinate will take the cursor position instead of specified coordinates points.
I think that weird result is an issue.
(tested on 2015 and 2016)
INSBASE and BASE set to 0,0,0
so I just need to know if any of you have same result..
thank you.
![Smiley :)](http://www.theswamp.org/Smileys/black/smiley.gif)
