Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
CAD Forums
CAD General
Topic:
Rebuild 3 Piece Exploded Leader?
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Rebuild 3 Piece Exploded Leader? (Read 2309 times)
MSTG007
Gator
I can't remeber what I already asked! I need help!
on:
June 19, 2015, 09:06:15 AM »
I am noticing a lot of details that have leaders exploded to them. The Arrow is a solid, then with the line and leadin line. Is there a routine that could rebuild or make it back to a mleader or something easily?
Logged
Civil3D 2020
Rob...
King Gator
Take a little time to stop and smell the roses.
Re: Rebuild 3 Piece Exploded Leader?
Reply #1 on:
June 19, 2015, 09:39:44 AM »
You too? We have the same problem. If that has happened, you may even find discrepancies in the arrow head size and possibly other inconsistencies.
I've been recreating the leaders manually.
Logged
CAD Tech
MSTG007
Gator
Reply #2 on:
June 19, 2015, 09:42:21 AM »
i will say this, I have seen lisp routines that can take a leader (that is not exploded) and then convert it to the default mleader style. That works pretty good. But hey, nothing wrong with asking...
Logged
Civil3D 2020
Rob...
King Gator
Reply #3 on:
June 19, 2015, 09:45:35 AM »
That is not hard to do and could be utilized if you find a way to rebuild them from what you have.
Logged
CAD Tech
MSTG007
Gator
Reply #4 on:
June 19, 2015, 09:49:33 AM »
That was kinda of the thought I had.... But could you imagine cleaning up details on the fly if this could work? Heck it would be awesome if you could do several at once. Go into the detail source dwg, select all the broken exploded texts and broke leaders and then magically convert them back to a mleader?
Logged
Civil3D 2020
Seagull
Every Student their own Lesson
WWW
Reply #5 on:
June 19, 2015, 09:54:13 AM »
The cool routine would be to somehow have the program find the fool that exploded all the leaders and unleash a horde of angry wasps on them.
Logged
Needs a day job
Reply #6 on:
June 19, 2015, 10:47:58 AM »
Do you have an example drawing? Does not seem like it would be too hard to accomplish.
Logged
MSTG007
Gator
Reply #7 on:
June 19, 2015, 11:45:31 AM »
Ron, I have sent you an email with some details in it.
Logged
Civil3D 2020
Bethrine
Guest
Reply #8 on:
June 19, 2015, 11:09:52 PM »
Those pesky things slowed me down about every other drawing. My condolences. I ended up putting them on their own layer then basically pasting mleaders over them. Then I deleted from the isolated layer.
I kept wishing the "find and replace" for text would work. Hope you guys solve this. ☺
Logged
Needs a day job
Reply #9 on:
June 22, 2015, 10:16:08 AM »
I don't think there's a 'magic bullet' for the detail you sent.
HERE's
something I wrote a while back that could help speed up the process a bit.
You could also try this quickly written code to speed up the process:
Code - Auto/Visual Lisp:
[Select]
defun
c:foo
_dxf lp lp2 lpe ml ss txt x
defun
_dxf
code ename
if
ename
cdr
assoc
code
entget
ename
;; Single pick cleanup
;; Requires all of the following items -->
cond
null
and
setq
ss
ssget
":L"
list
0
"text,line,solid"
setq
ss
vl
remove
if
listp
mapcar
cadr
ssnamex
ss
print
"Bye..."
not
setq
lp
_dxf
12
setq
lpe
car
vl
remove
if
not
lambda
x
"SOLID"
_dxf
0
x
ss
print
"Leader point not found..."
not
setq
lp2
car
vl-sort
apply
append
mapcar
lambda
x
list
_dxf
10
x
_dxf
11
x
vl
remove
if
not
lambda
x
"LINE"
_dxf
0
x
ss
lambda
a b
distance
a lp
distance
b lp
print
"Lines not selected..."
not
setq
txt
vl-sort
vl
remove
if
not
lambda
x
"TEXT"
_dxf
0
x
ss
lambda
a b
cadr
_dxf
10
a
cadr
_dxf
10
b
print
"Text not selected..."
t
command
"._mleader"
lp lp2
setq
ml
vlax
ename
vla-object
entlast
vla-put-textstring
ml
vl-string-right-trim
P"
apply
strcat
mapcar
lambda
x
strcat
_dxf
1
x
P"
txt
vla-put-layer
ml
_dxf
8
car
txt
;; Suggest using an mleader style rather than these hardcoded values below :)
;; may Sh!+ the bed depending on the CMLEADERSTYLE
vla
put
textstylename ml
_dxf
7
car
txt
vla-put-textheight
ml
_dxf
40
car
txt
vla-put-arrowheadsize
ml
distance
lp
_dxf
10
lpe
mapcar
entdel
ss
princ
Logged
MSTG007
Gator
Reply #10 on:
June 22, 2015, 10:47:44 AM »
That is some pretty wild stuff. Crazy how you had that laying around. lol. Everything is pretty much as needed minus the select everything and it does it. But like you said most of the work is done. Could there be a way if there is a qleader that it could use that as well? or in the routine it could accept it and explode it then convert it over? Again SWEET!
Logged
Civil3D 2020
Needs a day job
Reply #11 on:
June 22, 2015, 11:16:31 AM »
I believe the code referenced
HERE
accounts for associated leaders. IMO it would be very easy to just explode the items you want to clean up before you run the code.
Logged
MSTG007
Gator
Reply #12 on:
June 22, 2015, 11:25:15 AM »
hehehe.... that is what I was thinking. placing it in a macro to do my exploding and then run the code:) Still very sweet code!
Logged
Civil3D 2020
Needs a day job
Reply #13 on:
June 22, 2015, 11:37:45 AM »
Glad you can make use of it
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
CAD Forums
CAD General
Topic:
