Author Topic: Batch hyperlinking based on attribute names in blocks  (Read 3924 times)
ahazen
« on: June 16, 2015, 11:34:30 AM »
I have hyperlinks to attach with names like 360-001.html or www.website.com/360-001. I was wondering if I could get help automating the hyperlinking process for these blocks. So block with attribute "001" would automatically be hyperlinked with www.website.com/360-001 when the command is run.
Re: Batch hyperlinking based on attribute names in blocks
« Reply #1 on: June 16, 2015, 11:36:59 AM »
Is the attribute TAG named "001" or is that the value for the attribute? .. BTW .. welcome to TheSwamp  :)
HERE's a thread you can reference for adding a URL to an object.
« Last Edit: June 16, 2015, 11:44:03 AM by ronjonp »
ahazen
« Reply #2 on: June 16, 2015, 11:48:44 AM »
Thanks for the welcome! I hope to learn  :lol:. The TAG is 001. In this specific situation the attribute value is 360. I want to utilize the tag.
ahazen
« Reply #3 on: June 16, 2015, 11:55:51 AM »
Wait. I meant I want the Value for the attribute. Sorry, I flipped those mentally. The tag is 360 and the value is 001.
« Reply #4 on: June 16, 2015, 12:02:57 PM »
Give this a try:
  1. (defun c:puturl (/ _ss2l tag val)
  2.   (defun _ss2l (ss / n result)
  3.     (if (= (type ss) 'pickset)
  4.       (repeat (setq n (sslength ss)) (setq result (cons (ssname ss (setq n (1- n))) result)))
  5.     )
  6.   )
  7.   (setq tag "360")
  8.   (regapp "PE_URL")
  9.   (foreach ename (_ss2l (ssget ":L" '((0 . "insert") (66 . 1))))
  10.     (if
  11.       (and
  12.         (vl-some '(lambda (x) (and (= tag (vla-get-tagstring x)) (setq val (vla-get-textstring x))))
  13.                  (vlax-invoke (vlax-ename->vla-object ename) 'getattributes)
  14.         )
  15.         (setq val (strcat "www.website.com/" tag "-" val))
  16.       )
  17.        (entmod (append (entget ename)
  18.                        (list (list -3
  19.                                    (list "PE_URL"
  20.                                          (cons 1000 val)
  21.                                          '(1002 . "{")
  22.                                          (cons 1000 val)
  23.                                          '(1002 . "{")
  24.                                          '(1071 . 0)
  25.                                          '(1002 . "}")
  26.                                          '(1002 . "}")
  27.                                    )
  28.                              )
  29.                        )
  30.                )
  31.        )
  32.     )
  33.   )
  34.   (princ)
  35. )
« Last Edit: June 17, 2015, 08:37:03 AM by ronjonp »
ahazen
« Reply #5 on: June 16, 2015, 12:16:34 PM »
That is working, I'll make some edits and get back to you, but that gave me the parts I was missing!
Thanks, that's a positive first impression to the forum!
« Reply #6 on: June 16, 2015, 12:25:40 PM »
Glad to help :)
« Reply #7 on: June 16, 2015, 12:56:15 PM »
Another, using ActiveX:
  1. (defun c:batchurl ( / h i o s v )
  2.      (if (setq s (ssget "_:L" '((0 . "INSERT") (66 . 1))))
  3.          (repeat (setq i (sslength s))
  4.              (if (setq o (vlax-ename->vla-object (ssname s (setq i (1- i))))
  5.                        h (vla-get-hyperlinks o)
  6.                        v (vl-some '(lambda ( x ) (if (= "360" (vla-get-tagstring x)) (vla-get-textstring x))) (vlax-invoke o 'getattributes))
  7.                  )
  8.                  (if (zerop (vla-get-count h)) (vla-add h (strcat "www.website.com/360-" v)))
  9.              )
  10.          )
  11.      )
  12.      (princ)
  13. )
The above will only add a new hyperlink if the block has no existing hyperlinks to avoid duplication.
« Last Edit: June 16, 2015, 01:02:19 PM by Lee Mac »
roy_043
  • BricsCAD 18
« Reply #8 on: June 16, 2015, 01:16:49 PM »
@ ronjonp:
You are using entmod twice. I think the first call is not necessary.
« Reply #9 on: June 16, 2015, 01:30:31 PM »
@ ronjonp:
Ahh yes .. that carried over from the other thread referenced to keep an existing hyperlink but change the text shown. Updated above.
roy_043
  • BricsCAD 18
« Reply #10 on: June 17, 2015, 06:36:11 AM »
I don't know the thread you are referring to. But whenever you write new Xdata for an aplication all the old data is automatically removed. You cannot update a single item or append data. So I think that in the 'other thread' there is then also a superfluous call to entmod. :wink:
« Reply #11 on: June 17, 2015, 08:36:25 AM »
I don't know the thread you are referring to. But whenever you write new Xdata for an aplication all the old data is automatically removed. You cannot update a single item or append data. So I think that in the 'other thread' there is then also a superfluous call to entmod. ;)
You are correct it is superfluous. I'll try to be better in the future  :P  We also need to check that PE_URL is registered before writing xdata ( updated in code above ) .
