Author Topic: adui16res.dll not found  (Read 22919 times)
« Reply #15 on: April 29, 2005, 06:53:52 AM »
That all looks good, but in a practical application does it really matter. I would suspect that provided the application does not interfere with another class or namespace it "shouldn't" make a difference. It would be an obvious problem if you duplicated the class name of an already existent class, such as in the example, Microsoft.Office ~ I don't see that being a problem while being used on a small scale, but it has broader implications on a large scale deployment.
The info is a good rule to follow, at least then you won't have to try and guess if the naming convention is what is creating your problem.
TR
« Reply #16 on: April 29, 2005, 02:28:52 PM »
I really have no idea why booc.exe (the boo compiler) is looking for adui16res.dll. The only assemblies I am referencing in my project are acdbmgd.dll and acmgd.dll so one of them must be referencing that file. If I have local copy set to True on both dll's it will also copy the adui16res.dll into my bin/debug directory. I am assuming that this is something to do with BOO as I have not seen that dll in any C# projects I have compiled. Also I've checked the references of both dll's and I do not see anything pointing to adui16res.dll.
« Reply #17 on: April 29, 2005, 07:13:36 PM »
Hi Tim,
This may be a dumb question but we have to start somewhere, are both of the managed wrapper dll's visible in your project solution explorer?
- John Carmack
- J.R.R. Tolkien
« Reply #18 on: April 29, 2005, 08:06:37 PM »
Good point. This is a snap of a solution view with VC#2005
Note that the DLL's are included as References.
You seem to have them as a Viewable/editadle file ??
user tip : when posting images do NOT have spaces in the file name.
This is the format, using img, not ximg, of course.
[ximg]http://www.theswamp.org/screens/kerry/SolutionExplorer.png[/ximg]
TR
« Reply #19 on: May 02, 2005, 11:57:56 AM »
Quote from: MickD
Hi Tim,
Yes both dlls are there.
« Reply #20 on: May 02, 2005, 05:10:59 PM »
Ok, next...(probably should have been first ;) )
Is this a class library project or an windows application (.exe)?
If it is an .exe, you can't use the managed wrappers, you will have to use the COM interface.
And what is 'BOO' (I hope that isn't a silly question  :oops: )
- John Carmack
- J.R.R. Tolkien
daron
« Reply #21 on: May 03, 2005, 08:18:00 AM »
Mick, have a read of this thread.
« Reply #22 on: May 03, 2005, 03:08:49 PM »
aahhh....Thanks Daron, that clears that piece of the puzzle up :)
- John Carmack
- J.R.R. Tolkien
