Author Topic: adui16res.dll not found  (Read 22920 times)
TR
« on: April 28, 2005, 10:48:15 AM »
I'm doing some BOO testing in SharpDevelop trying to create an AutoCAD command that returns a string to the command line. I have references to acmgd.dll and acdbmgd.dll but when I try to compile my program I get an error message saying "adui16res.dll not found". This doesn't make sense because adui16res.dll is located in the same directory as acmgd.dll and acdbmgd.dll. I'll keep working on it but if anyone has any thoughts or ideas I'd love to hear them.
Here is a Screenshot of my error.
tjr
« Reply #1 on: April 28, 2005, 10:54:24 AM »
Hmmm, dunno. What's on lines 21 and 22?
Off topic: Is it good to have a namespace and class share the same name?
TR
« Reply #2 on: April 28, 2005, 11:03:12 AM »
Quote from: MP
21: [assembly: AssemblyTitle('BooHoo')]
22: [assembly: AssemblyDescription('A test for using BOO with AutoCAD')]
Assembly information for my dll.
Quote from: MP
I don't think it matters as I've seen it done before. If someone where to import my assembly they would just be referencing BooHoo.BooHoo.
« Reply #3 on: April 28, 2005, 11:33:31 AM »
Sorry Tim, have no ideas.
« Reply #4 on: April 28, 2005, 05:34:42 PM »
Does anyone know what adui16res does. ?
Can I assume some sort of user interface Resources stuff ?
.. similarly acui16 and acui16res and adui16
I'm guessing .. paletes ???
I <just now> tried to reference it into a C# project .. no go, not compatible .. but I AM using ac2005, not 2006 .. if that makes a difference.
« Reply #5 on: April 28, 2005, 05:43:27 PM »
It's not on this pc so my guess is right along side yours.
On the other hand it could be A Damned Unavailable Interface (for AutoCAD 16) Requiring Exhaustive Searching ...
« Reply #6 on: April 28, 2005, 05:48:02 PM »
heh, good guess
... that opens the door for some interesting<perhaps> acronyms.
« Reply #7 on: April 28, 2005, 05:53:36 PM »
Hey hey hey keep it clean ...
« Reply #8 on: April 28, 2005, 06:52:42 PM »
Quote from: Kerry Brown
It contains the resources required for adui16.dll
It is required for the interface to the ToolPalette object and transparency settings.
The file contains bitmaps, cursors, dialogs, string tables, menus and the such.
« Reply #9 on: April 28, 2005, 07:00:02 PM »
Thanks Keith, that was my Guess ..
Wonder why Tim's stuff is trying to reference it ?
<kwb definition> stuff : technical term relating to a wide variety of stuff.
« Reply #10 on: April 28, 2005, 07:01:37 PM »
Oooh, recursive def'n.
« Reply #11 on: April 28, 2005, 07:14:44 PM »
hehehehe .. I thought you'd recognise that ..
« Reply #12 on: April 28, 2005, 07:23:02 PM »
Oh the shame to be so predictable.
:oops:
« Reply #13 on: April 29, 2005, 04:58:40 AM »
Quote from: Tim Riley
Quote from: MP
Tim, I missed this comment,
... actually, It does make a difference :
http://msdn.microsoft.com/library/default.asp?url=/library/en-us/cpgenref/html/cpconnamespacenamingguidelines.asp
« Reply #14 on: April 29, 2005, 05:03:41 AM »
I knew I had read that at some point; good eye there Mr. Brown.
