Author Topic: Excel to Autocad insert Attribute Block  (Read 4701 times)
gungor
« on: June 10, 2015, 05:23:35 AM »
Hello,
I found a VBA code from the internet. Code blocks according to the positioning coordinates in AutoCAD.
code is working but for simple block.
I wanted change for attribute block but I can not do.
Who can help?
I hope that me understand. because my english Too bad  :-)
Option Explicit
'A custom type that holds the scale factors of the block.
Private Type ScaleFactor
    X As Double
    Y As Double
    Z As Double
End Type
Sub InsertBlocks()
    'Inserts blocks in AutoCAD using data - insertion point, block name/full path, scale factors, rotation angle - from Excel.
    'Note that the block name or the block path must already exists, otherwise nothing will be inserted.
    'The code uses late binding, so no reference to external AutoCAD (type) library is required.
    'It goes without saying that AutoCAD must be installed at your computer before running this code.
    'Written by:    Christos Samaras
    'Date:          21/04/2014
    'e-mail:        xristos.samaras@gmail.com
    'site:          http://www.myengineeringworld.net
         ' Define the block
    'Declaring the necessary variables.
    Dim acadApp                 As Object
    Dim height                  As Double
    Dim acadDoc                 As Object
    Dim acadBlock               As Object
    Dim attributeObj            As Object
    Dim LastRow                 As Long
    Dim i                       As Long
    Dim InsertionPoint(0 To 2)  As Double
    Dim BlockName               As String
    Dim BlockScale              As ScaleFactor
    Dim RotationAngle           As Double
    Dim tag                     As String
    Dim value                   As String
    Dim prompt                  As String
    tag = "ATT1"
    value = Range("E3")
    height = 250
    'Activate the coordinates sheet and find the last row.
    With Sheets("Coordinates")
        .Activate
        LastRow = .Cells(.Rows.Count, "A").End(xlUp).Row
    End With
    'Check if there are coordinates for at least one circle.
    If LastRow < 2 Then
        MsgBox "There are no coordinates for the insertion point!", vbCritical, "Insertion Point Error"
        Exit Sub
    End If
    'Check if AutoCAD application is open. If is not opened create a new instance and make it visible.
    On Error Resume Next
    Set acadApp = GetObject(, "AutoCAD.Application")
    If acadApp Is Nothing Then
        Set acadApp = CreateObject("AutoCAD.Application")
        acadApp.Visible = True
    End If
    'Check (again) if there is an AutoCAD object.
        MsgBox "Sorry, it was impossible to start AutoCAD!", vbCritical, "AutoCAD Error"
        Exit Sub
    End If
    On Error GoTo 0
    'If there is no active drawing create a new one.
    Set acadDoc = acadApp.ActiveDocument
    If acadDoc Is Nothing Then
        Set acadDoc = acadApp.Documents.Add
    End If
    On Error GoTo 0
    'Check if the active space is paper space and change it to model space.
    If acadDoc.ActiveSpace = 0 Then '0 = acPaperSpace in early binding
        acadDoc.ActiveSpace = 1     '1 = acModelSpace in early binding
    End If
    'Loop through all the rows and add the corresponding blocks in AutoCAD.
        For i = 2 To LastRow
            'Set the block name.
            BlockName = .Range("D" & i).value
            'If the block name is not empty, insert the block.
            If BlockName <> vbNullString Then
                'Set the insertion point.
                InsertionPoint(0) = .Range("A" & i).value
                InsertionPoint(1) = .Range("B" & i).value
                InsertionPoint(2) = .Range("C" & i).value
                'Initialize the optional parameters.
                BlockScale.X = 1
                BlockScale.Y = 1
                BlockScale.Z = 1
                RotationAngle = 0
                'Add the block using the sheet data (insertion point, block name, scale factors and rotation angle).
                'The 0.0174532925 is to convert degrees into radians.
                Set attributeObj = acadBlock.AddAttribute(height, _
                          prompt, InsertionPoint, tag, value)
                Set acadBlock = acadDoc.ModelSpace.Insertblock(InsertionPoint, BlockName, _
                                BlockScale.X, BlockScale.Y, BlockScale.Z, RotationAngle * 0.0174532925)
            End If
        Next i
    End With
    'Zoom in to the drawing area.
    acadApp.ZoomExtents
    'Release the objects.
    Set acadBlock = Nothing
    Set acadDoc = Nothing
    Set acadApp = Nothing
piscopatos
Re: Excel to Autocad insert Attribute Block
« Reply #1 on: September 06, 2015, 08:27:49 AM »
selam güngör,
i believe, you need to do some study.  "AutoCAD+2006+VBA+-+A+Programmers+Reference" will help you alot.
good luck.
