Author Topic: Can't shell , change in topology detected.  (Read 2524 times)
andy_lee
« on: June 09, 2015, 06:19:32 AM »
Hi all
Sometimes , use autocad edit 3d solid . I found a BUG,  it's BUG ? maybe.
The problem is : can't "shell" , use command "shell" ,but err.
like this:
Modeling Operation Error:
     Change in topology detected.
Manual solution: move this solid to 0,0,0 , use "shell" ---ok!
I don't know why need do this (move), It's a BUG?
If I move this solid , when finish the "shell" , I need move it back . So this is not a smart way .
Can use coding to solve this problem?
attachment is a test file (can't shell)
Thanks.
« Last Edit: June 09, 2015, 08:25:36 AM by emk2012 »
andy.
Best regards.
andy_lee
Re: Can't shell , change in topology detected.
« Reply #1 on: June 10, 2015, 07:10:26 AM »
Dear all
I think can like this:
use Lee's routine to get the center of gravity solids  (http://www.cadtutor.net/forum/showthread.php?92354-Center-of-gravity) ,Get the coordinates of the point(center of gravity) . remember
move this solid to 0,0,0 , zoom --->object.
shell
move this solid back to that coordinates.---->zoom --object
finish
Thanks for any help.
« Last Edit: June 10, 2015, 07:14:48 AM by emk2012 »
andy.
Best regards.
