Author Topic: Revit Tips and Tricks  (Read 17908 times)
Matt__W
  • I like my water diluted.
Re: Revit Tips and Tricks
« Reply #30 on: June 08, 2015, 03:00:21 PM »
"He" means this.  :)
Changing the linked view settings.
Autodesk Expert Elite
Rob...
« Reply #31 on: June 08, 2015, 03:06:25 PM »
Do you adjust model category settings at all or is it strictly by linked view?
On a side note, this is a great thread. I'm learning a lot.
CAD Tech
Matt__W
« Reply #32 on: June 08, 2015, 03:09:23 PM »
Occasionally I'll have to adjust the model cats. Maybe turn off the detail category and some of the lines. And like I said, we tweak the annotation as well to turn off grids (we copy/monitor them so we have full control over if they all adjust in cropped views), dimensions, text, tags, etc...
John Kaul (Se7en)
« Reply #33 on: June 08, 2015, 03:11:25 PM »
Ah, I thought you meant "By Linked View" (that middle toggle button at the top).
Matt__W
« Reply #34 on: June 08, 2015, 03:12:10 PM »
I am setting a linked view but then I'm tweaking it.
John Kaul (Se7en)
« Reply #35 on: June 08, 2015, 03:20:14 PM »
Each view? Each level?
Matt__W
« Reply #36 on: June 08, 2015, 03:30:33 PM »
When I set up my template project, I created a view template (FLOOR_01) with all of the settings I wanted to use for the first floor. I then duplicated that view template and renamed it to FLOOR_02. I changed the linked view from first floor to second floor. All other settings remained as-is. I repeated this process to create a total of 15 view templates - one for each floor. I have custom project browser settings that I use to organize views into new, existing, demo, by levels, etc.... I set the project browser to display all new views by level. I then selected all of the first floor trade views - HVAC, plumbing, fire protection, etc - and applied the FLOOR_01 view template. I did this for all of the 15 floors in my template project. It sounds like a lot of work but I got it set up in probably less than an hour (once I got my view settings EXACTLY how I wanted them).
John Kaul (Se7en)
« Reply #37 on: June 09, 2015, 07:53:03 AM »
I'm sorry, but that does sound way too complicated. So, in theory, to set up a project you'd have to re-adjust up to 15 view templates (nope, not for me)?
Rob...
« Reply #38 on: June 09, 2015, 07:56:52 AM »
I thought I had a lot of view templates. I haven't had a need for different view templates for different floors. Why are you guys doing that?
CAD Tech
Matt__W
« Reply #39 on: June 09, 2015, 08:09:04 AM »
What would have to be re-adjusted?? It's in the template. You swap out the placeholder architectural model with the actual project model, align the levels if need be and you're done.
John Kaul (Se7en)
« Reply #40 on: June 09, 2015, 08:21:45 AM »
Template: View is linked to FLOOR_01
New Link: View to link to is FIRST LEVEL-ricky
How does your template know to look for the right view without some updating of those templates?
John Kaul (Se7en)
« Reply #41 on: June 09, 2015, 08:23:15 AM »
I would imagine the little settings like "view ranges" and whatnot that can be different per floor.
Matt__W
« Reply #42 on: June 09, 2015, 08:24:54 AM »
That would be the ONLY thing that needs to be updated.
As for View Ranges, I have the top view range set to LEVEL ABOVE (minus 6" to accommodate for decking above) so that's not an issue.
Rob...
« Reply #43 on: June 09, 2015, 08:30:22 AM »
If I need something other than the level above and below and maybe an offset, I take view range out of the template.
CAD Tech
John Kaul (Se7en)
« Reply #44 on: June 09, 2015, 08:35:12 AM »
Hey, no biggie to me; I just feel that is too much work tracking down those views and making the changes in each of those view templates. Every method has bottle necks and some methods will work better in different situations.
