Author Topic: xref color  (Read 3850 times)
Fabricio28
xref color
« on: June 03, 2015, 02:30:36 PM »
Hi guys,
I've created a xref file, and I have 3 different color in layer named test (the color is not by layer).
So I have to change the color of all objects to color 253.
How Can I do that?
I couldn't change the colors objects from the main project, just the xref file.
I tried to create a filter layer and change the color, but isn't working.
Thank you
Matt__W
  • I like my water diluted.
Re: xref color
« Reply #1 on: June 03, 2015, 02:32:39 PM »
They need to BYLAYER in the xref file for you to be able to change the color in the main project drawing.
Autodesk Expert Elite
Rob...
Re: xref color
« Reply #2 on: June 03, 2015, 02:33:23 PM »
Separate the three colors into three layers and use color By Layer. The color can then be changed in the referencing file.
CAD Tech
Re: xref color
« Reply #3 on: June 03, 2015, 02:34:01 PM »
If not BYLAYER not much you can do to override them
Fabricio28
Re: xref color
« Reply #4 on: June 03, 2015, 03:02:57 PM »
Really?  :cry:
I think I could managed the color from objects in xref file.
Without changed the main file.
Fabricio28
Re: xref color
« Reply #5 on: June 03, 2015, 03:03:44 PM »
It could be good.
I think it is the only way.
rkmcswain
Re: xref color
« Reply #6 on: June 03, 2015, 03:22:39 PM »
AutoCAD 2016 allows you to change the color of any xref entity regardless if it's set to BYLAYER in the child drawing.
Check the XREFOVERRIDE sysvar.
alanjt
  • Standby for witty remark...
Re: xref color
« Reply #7 on: June 04, 2015, 09:18:04 AM »
This might be the best thing I've heard of from Autodesk in a long time. I don't know how many architect plans I've exploded over and over to get all the blocks down to lines just so I could change all objects to be bylayer.
Dropbox
Re: xref color
« Reply #8 on: June 04, 2015, 10:20:56 AM »
I've been using THIS gem to accomplish bylayer for about 12 years now  :)
Re: xref color
« Reply #9 on: June 04, 2015, 01:11:05 PM »
Ha, that's some old siht! :)
Matt__W
Re: xref color
« Reply #10 on: June 04, 2015, 01:15:13 PM »
Kinda looks like the equivalent to Autodesk's SETBYLAYER command.
Re: xref color
« Reply #11 on: June 04, 2015, 02:27:38 PM »
Yeah it is .. but still works great :)
alanjt
Re: xref color
« Reply #12 on: June 05, 2015, 10:24:33 AM »
No kidding. Thanks, Michael!
Dropbox
lamarn
Re: xref color
« Reply #13 on: June 06, 2015, 10:54:09 AM »
M@yhem, does a setbyblock command exist? (without trying google in the first place).. I wonder because I byblock many of my time ;-)
