Author Topic: DXF Reading  (Read 2143 times)
GumbyCAD
DXF Reading
« on: May 30, 2015, 01:13:33 AM »
Does anyone know if you can read in a DXF into AutoCAD and get the Polygons that are returned from the DXF?
If that makes sense?
huiz
  • Certified Prof C3D
Re: DXF Reading
« Reply #1 on: May 30, 2015, 09:25:17 AM »
You can create a temporary database, import the DXF in that (Database.DxfIn()), iterate through the ObjectIds and get the Polygons and clone them. Or you can insert the DXF in the current Database (Database.Insert()) and iterate through the entities to remove everything that is not a Polygon.
GumbyCAD
Re: DXF Reading
« Reply #2 on: May 30, 2015, 09:50:26 PM »
Thanks Ill try that
Re: DXF Reading
« Reply #3 on: June 01, 2015, 08:02:57 AM »
DXFs are usually ASCII and can therefore be read fairly easily.
http://netdxf.codeplex.com/
