Author Topic: Working with Civil 3D Using COM and VS 2013  (Read 1351 times)
slingblade
  • Mosquito
« on: May 24, 2015, 10:14:11 PM »
I am using Visual Studio 2013 and Civil 3D 2015.
I am trying to find the AeccAlignment object (Civil 3D). It used to be in AeccXLand and I made a COM reference in Visual Studio to access it. i have read and understand that now I have to browse to the install directory as COM libraries are no longer installed and that is fine. However I cannot see any dll's that look like they would be correct. I have googled and read as much as I can but I have not found how we use the COM libraries to work with with Civil 3D now.
BTW I am looking for the Autodesk.AECC.Interop.Land, Autodesk.AECC.Interop.UILand and Autodesk.AECC.Interop.UIBase namespaces.
Where are we going and why am I in this hand-basket?
slingblade
  • Mosquito
Re: Working with Civil 3D Using COM and VS 2013
« Reply #1 on: May 24, 2015, 11:46:42 PM »
Don't worry unless its an easy answer, I have decided to port the program to run with native code instead of COM.
« Reply #2 on: May 25, 2015, 09:53:26 AM »
You will find them here:
C:\Program Files\Autodesk\AutoCAD 2015\C3D
