Author Topic: Edit a Text Style?  (Read 19321 times)
Bethrine
  • "Life is the greatest adventure.", Peter Pan
Edit a Text Style?
« on: May 21, 2015, 01:16:53 PM »
Okay, I have been looking for this setting, preferably for MTEXT. It is bold everywhere I put it and I can't get rid of it. Other than that, I do not want to change the text style. I could create a new one but it should be easier to just adjust my present one. I have looked and looked and I am missing something obvious...again... :crazy2:
FYI, I want to edit the text style permanently in a template drawing.
TIA
AutoCAD 2014, Inventor 2014, TurboNest 2012
I only get one life. I'm going to have fun living it. Find joy in everything.
Re: Edit a Text Style?
« Reply #1 on: May 21, 2015, 01:18:40 PM »
Try clicking inside highlight the text then right-click and choose remove formatting.
Or a quick explode will remove also if it formatting.
Bethrine
« Reply #2 on: May 21, 2015, 01:22:55 PM »
That's what I have been doing. I don't want to have to do it every drawing, every text object.
Rob...
« Reply #3 on: May 21, 2015, 01:26:10 PM »
So, the text has been modified to override the style settings?
I have a LISP, STPMtext, that removes the overrides.
CAD Tech
Bethrine
« Reply #4 on: May 21, 2015, 01:36:30 PM »
Not sure, I haven't heard of a STYLE command...? Might be what I'm looking for...
Yup, ...I feel sorta dumb right now.  :uglystupid2: Fontstyle was set to Bold.
I might as well set up my own text style. I change it and it changes back. <sigh> Maybe it's only changing it per drawing? And then I have to go back and fix it.
Come to think of it, maybe your LISP is exactly what I need... :wink:
Bethrine
« Reply #5 on: May 21, 2015, 01:41:38 PM »
One of the things I want to fix, though, is it says text height says 0" in style but it prints just fine and it's NOT annotative. I'm annoyed by that. I want to print it at 3/32", not 1/8".
Don't get me wrong, I can "play" with text all day long but I don't want to have to any more.
I like the idea of annotative text, but I ran into a problem with it earlier and now I can't remember what it is.
So yeah, I guess I have a tutorial or two in front of me.
Rob...
« Reply #6 on: May 21, 2015, 01:43:08 PM »
If changing the text style did what you wanted, then the style isn't overridden in the MText.
Yes, the style is stored in each .dwg.
CAD Tech
« Reply #7 on: May 21, 2015, 01:58:45 PM »
however...one can set up a brand new file
create text styles with all the settings one desires...
and then through the MAGIC of the Parent Child relationship of drawings
One inserts the file with the *BAD* settings in it - it then inherits the new $GOOD$ settings
and then one wblocks it out to the wen and improved version of it's former self.
*CAD Wizard hat and robe is optional for this operation to work*
Bethrine
« Reply #8 on: May 21, 2015, 01:59:14 PM »
So do I have to start a template drawing from scratch in order to set the text up how I want it?
i.e.a default text style:
Height
Annotative or not
Style Type
etc.
Bethrine
« Reply #9 on: May 21, 2015, 02:02:42 PM »
Oh, I see. I had to back up and re-read.
Darn.
« Reply #10 on: May 21, 2015, 02:02:48 PM »
Height
Annotative or not
Style Type
etc.
Probably the easiest way to impose your will on multiple files.
« Reply #11 on: May 21, 2015, 02:03:42 PM »
wblock out two or three pieces of the offending text...post that file here for review and advisement
Bethrine
« Reply #12 on: May 21, 2015, 02:05:06 PM »
Height
Annotative or not
Style Type
etc.
 :blink:
Wait a minute...
If I do that, will it hit every file ? I just want to adjust the ones I work on. I want to be able to open old drawings WITHOUT changing them.
Bethrine
« Reply #13 on: May 21, 2015, 02:12:37 PM »
No longer the problem.  :-D It was bold in a text leader. I just told it to un-bold. Problem is, the applied text style is bold so it affects all text. I can un-bold it in each place but I want to un-bold it overall.
« Reply #14 on: May 21, 2015, 02:36:08 PM »
post sample...it is easiest way for us to advise
nevermind, without lisp or other programing I don't see any easy fix for this....
« Last Edit: May 21, 2015, 02:44:41 PM by mjfarrell »
