Author Topic: AutoCAD 2016 pdf custom paper size  (Read 9407 times)
Jeff H
« on: May 21, 2015, 11:36:45 AM »
Has anyone had problems with 2016 pdf driver when publishing with a  custom paper sizes?
Bethrine
Re: AutoCAD 2016 pdf custom paper size
« Reply #1 on: May 21, 2015, 12:23:03 PM »
I just "fixed" my PDF output but I'm still on on AutoCAD 2014.
Jeff H
« Reply #2 on: May 21, 2015, 01:03:14 PM »
I have not successfully published a pdf that uses custom size, or I have done single page and not able to do multiple sheet pdf.
ChrisCarlson
« Reply #3 on: May 21, 2015, 01:26:04 PM »
No issues here, DWG to PDF will attempt to make a custom page size if under options -> Plot and Publish -> Keep the layout paper size if possible is checked.
« Reply #4 on: May 21, 2015, 02:00:03 PM »
best to create a named page setup for this - making sure to create and specify your 'custom' page size while doing so
Jeff H
« Reply #5 on: May 21, 2015, 02:56:15 PM »
I created fuc%$*ng 5 different ones, I imported and set the layouts to same setup, I re-installed, repaired, plotted custom paper size with KIP, DWF from same drawing of pagesetups.
I tried resetting everything to default and added custom size to default pc3 file, put it in same folder.
Tried on 3 other computers.
Created some other drawings with 2016, 2015, 2013 that had a line and empty  to try.
Sometimes it tells me that the plotting folder is read-only and cannot write to file, even though it does not needto, sometimes no info, sometimes cannot find device, sometimes dies immediately, sometimes tries first sheet for 5 to seconds then dies, background, foreground, does not matter.
Can Plot a single one, tried about every different setting you could and 2015 works fine.
I pretty much at point asking people I work with if they would like to have meltdown in conference so they watch and enjoy, or just print it 2015.
Bethrine
« Reply #6 on: May 21, 2015, 03:02:59 PM »
I know your pain. Think zen-like thoughts (unless they irritate you). mj can be frustrating but he knows what he's doing in my experience. You are in capable hands.
Gooooz-frabba.
« Reply #7 on: May 21, 2015, 03:09:00 PM »
what size are you after?
that makes it such a pain point?
AND is it really a custom page size you are after?
« Reply #8 on: May 21, 2015, 03:13:12 PM »
further....you are probably aware that Autodesk has muddied the waters in 2016 with these four(4) YES FOUR!!!! PDF 'presets'?
PDF Presets/PC3 files shipped with the system
PC3 File / PDF Preset   Purpose
DWG to PDF.pc3   General purpose driver used in AutoCAD 2015 and earlier.
AutoCAD PDF (General Documentation).pc3   General purpose driver suitable for most uses.
AutoCAD PDF (High Quality Print).pc3   Produces a PDF file optimized for printing on paper.
AutoCAD PDF (Smallest File).pc3   Produces a PDF with the smallest possible file size.
AutoCAD PDF (Web and Mobile).pc3   Produces a PDF file that supports hyperlinks mobile devices and Web browsers.
Jeff H
« Reply #9 on: May 21, 2015, 03:22:48 PM »
They like having the entire base 1-line on the wall in their office and main substation which this particular one fits on two 78"x36" sheets.
Done it many times before just not with 2016.
« Reply #10 on: May 21, 2015, 03:36:59 PM »
try the attached...pagesetup and pc3
you might want to just XREF your file in and make a viewport
« Reply #11 on: May 21, 2015, 04:28:15 PM »
Gooooz-frabba.
Thanks.....
I think?  ?  ?  ?
Bethrine
« Reply #12 on: May 21, 2015, 04:33:50 PM »
Gooooz-frabba.
Thanks.....
I think?  ?  ?  ?
It often seems you are doing things the hard way BUT I have learned a TON by following through and in the long run, your advice always either makes my life easier or I end up with an in depth understanding that winds up serving me well in other areas.
So YES, that is a compliment.  :-)
« Reply #13 on: May 21, 2015, 04:46:35 PM »
My methods are often NOT for expediency, they are more for long term efficiency and usually have a high efficacy rating.
However they do offer productivity gains in both the short and long term.
« Reply #14 on: May 21, 2015, 04:47:04 PM »
Jeff?  What are you doing?
