Author Topic: Exporting DWG (similar as PDF)  (Read 12599 times)
Rob...
Re: Exporting DWG (similar as PDF)
« Reply #45 on: May 21, 2015, 04:41:39 PM »
(I'm sorry, but I'm having trouble understanding some of your English.)
It looks like you are using different settings for PDF from Revit than you are for exporting. I'm going to have to explore this a bit more and will let you know my findings after I get a chance to find them.
CAD Tech
lamarn
« Reply #46 on: May 22, 2015, 02:14:59 AM »
No.
It's one file created from Revit
The other one is export from Revit in dwg shapes.
Sorry for my english
hudster
« Reply #47 on: June 04, 2015, 05:01:52 AM »
Its the graphical changes from revit to DWG I can't stand. In the dwg export, it changes things for no apparent reason.
See below
Top image is PDF from Revit, bottom image is DWG export
