Author Topic: can't purge  (Read 6530 times)
Andrea
can't purge
« on: May 20, 2015, 02:34:21 PM »
Hi all,..
I'm stuck with a drawing who it can't be purged.
drawing contain nothing....but 1.270MB with a bunch of layers...
any one can help me to understand what its going wrong with this file ?
Thank you.
Keep smile...
kruuger
Re: can't purge
« Reply #1 on: May 20, 2015, 03:05:19 PM »
Hi all,..
Thank you.
CTRL+A lot of proxy stuff
k.
Andrea
Re: can't purge
« Reply #2 on: May 20, 2015, 03:15:37 PM »
Thank you...I know ...but it seem that they can't be deleted..
Keep smile...
kruuger
Re: can't purge
« Reply #3 on: May 20, 2015, 03:22:16 PM »
(command "-exporttoautocad" "f" "2000" "s" "_repaired" "" "")reduce size to 500k, delete few layers, blocks but still proxy crap  :x
kruuger
Re: can't purge
« Reply #4 on: May 20, 2015, 03:25:32 PM »
Andrea
Re: can't purge
« Reply #5 on: May 20, 2015, 03:33:45 PM »
thank you....I've tried many LISP and ARX routine created and/or found over the net...but nothing to fix this stupid drawing...
the fact is,...that I'm trying to understand how the proxy is linked to the Layer,...or if it is related.
I've also tried LAYDEL,...seem to work, but PROXY stay alive.
If I use ALT+D to the Layer panel,...It do not delete layer.
Keep smile...
kruuger
Re: can't purge
« Reply #6 on: May 20, 2015, 03:42:48 PM »
yep, really tough opponent...
bilançikur
Re: can't purge
« Reply #7 on: May 20, 2015, 03:57:45 PM »
there seem to be a lot of blocks in the dwg wich are also not purged, maybe they are somehow connected to the proxy entities?
Andrea
Re: can't purge
« Reply #8 on: May 20, 2015, 04:01:54 PM »
the only block who I can't purge is "_OBLIQUE"
my drawing is now reduced to 194ko, but still have 3423 Proxy entity in the drawing..
I've found
((-1 . <Entity name: 7ffffba6830>) (0 . "DICTIONARY") (330 . <Entity name: 7ffffba6820>) (5 . "3")
(100 . "AcDbDictionary") (280 . 1) (281 . 1) (3 . "ACAD_GEOGRAPHICDATA")
(360 . <Entity name: 7ffffba6840>) (3 . "ACAD_SORTENTS")
(360 . <Entity name: 7ffffb083f0>))
but can't able to remove this..XDATA.
Keep smile...
kruuger
Re: can't purge
« Reply #9 on: May 20, 2015, 04:07:36 PM »
I've found
but there is no _oblique in this dwg. this block is often used for dim style.
k.
EDIT
aa sorry. it was in original. it was used by STANDARD dim style. need to change to other and than purge without any problem.
k.
« Last Edit: May 20, 2015, 04:13:08 PM by kruuger »
Andrea
Re: can't purge
« Reply #10 on: May 20, 2015, 04:08:49 PM »
was finaly able to purge it...by redefine the bloc and delete. :)
but still have PROXY crap.
Keep smile...
Re: can't purge
« Reply #11 on: May 20, 2015, 04:14:16 PM »
Save as DXF 12 .. does not make round trip.
kruuger
Re: can't purge
« Reply #12 on: May 20, 2015, 04:16:16 PM »
check this Andrea. turn on your ribbon. what the he...
Andrea
Re: can't purge
« Reply #13 on: May 20, 2015, 04:18:51 PM »
thank you Ron...
the fact is...
the original drawing contain lot of stuff,...who cannot be "DXFed" to prevent loosing some entity propreties.
Lot of these king of drawings here...:|
Keep smile...
Andrea
Re: can't purge
« Reply #14 on: May 20, 2015, 04:22:05 PM »
? something supposed to happen ?
Keep smile...
