Author Topic: can't purge  (Read 6507 times)
kruuger
Re: can't purge
« Reply #15 on: May 20, 2015, 04:24:38 PM »
check this Andrea. turn on your ribbon. what the he...
? something supposed to happen ?
there is geolocation menu. which normally doesnt occur in dwg.
k.
Andrea
Re: can't purge
« Reply #16 on: May 20, 2015, 04:34:46 PM »
Keep smile...
Andrea
Re: can't purge
« Reply #17 on: May 20, 2015, 04:41:37 PM »
THAT ONE DID THE TRICK !!
http://www.maestrogroup.com.ua/support/ExplodeProxy.zip
From Alexander Rivilis. :)
« Last Edit: May 20, 2015, 04:48:37 PM by Andrea »
Keep smile...
Andrea
Re: can't purge
« Reply #18 on: May 20, 2015, 04:53:50 PM »
Oops !?
maybe Hoora to fast..
its seem that PROXY object cannot be find with..
(ssget "_X" '((0 . "*PROXY*")))
but I cannot XREF in a new drawing..:\
Keep smile...
Andrea
Re: can't purge
« Reply #19 on: May 20, 2015, 05:05:05 PM »
ok,...there is what I did...
I've copy all drawing from 0,0 to 1000,0
then, erase the first selection..
then move all drawing from 1000,0 to 0,0
then Purge all drawing.
seem to fix the issue.
but still that I do not know why.
Keep smile...
Crank
Re: can't purge
« Reply #20 on: May 22, 2015, 02:05:06 AM »
You don't have to move:
- Make sure everything is visible
- ERASE ALL REMOVE CROSSING (select everything)
- PURGE
Andrea
Re: can't purge
« Reply #21 on: May 25, 2015, 12:37:33 PM »
- PURGE
in the original file...I've lot of entities..
but you'Re right..I've to copy all 0,0 to 0,0 and Erase Previous.
then,..Purge.
Keep smile...
Crank
Re: can't purge
« Reply #22 on: May 26, 2015, 07:05:38 AM »
I don't understand why you first have to use the COPY command and than erase previous: Use the original entities.
If the drawing is really big then you can first turn of the HIGHLIGHT.
Patrick_35
Re: can't purge
« Reply #23 on: May 26, 2015, 10:42:56 AM »
hi
You can try JAV
77077
Re: can't purge
« Reply #24 on: May 27, 2015, 09:46:12 PM »
hi
You can try JAV
Thanks ,It's Russian ?
kruuger
Re: can't purge
« Reply #25 on: May 28, 2015, 03:41:35 AM »
hi
You can try JAV
c'mon 77077  ;D  you dont know cyrlica ?
it is french
k.
