Why not redefine the block that is inserted 40+ times (call it block 0)? Or do you have say 80 inserts of block 0 and need to add block 1 at only 40 of them?
If the latter, copy the 40, paste into blank drawing. Rename block definition from block 0 to block 1, copy/paste back into original drawing using same origin. Voila!
