I have a class called Class1 that inserts a drawing to the current drawing as a block. I also have a method in another class called Class2 that calls the Insertion Block from the Class2. If I call this method from another method in Class2, what will be the return type? Confused? Here is a sample code.
Class1:
public void Insert(...)
Class2:
private Class1 Method1()
Class1 insBk = new Class1();
insBk.Insert(...);
return insBk;
private void Method2(..)
Class1 cls1 = Method1(...);
What will this return? May be a dumb question. But can I change it to a block reference?
