Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
.NET
Topic:
Point3d X value
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Point3d X value (Read 2560 times)
shers
Guest
Point3d X value
on:
May 18, 2015, 12:07:03 PM »
It is not possible to assign value to Point3d Coordinates one by one, like Point3d insPt.X = 2. Is there any other option?
Logged
King Gator
C3D user & customizer
Re: Point3d X value
Reply #1 on:
May 18, 2015, 12:37:35 PM »
Point3d newpt = new Point3d(2, insPt.Y, insPt.Z);
Logged
BlackBox
King Gator
Re: Point3d X value
Reply #2 on:
May 18, 2015, 12:43:26 PM »
Duplicate thread here:
http://forums.augi.com/showthread.php?161727-Point3d
Logged
gile
Gator
Marseille, France
WWW
Re: Point3d X value
Reply #3 on:
May 18, 2015, 12:45:06 PM »
The type Point3d, as many others .NET structures, is immutable.
You cannot edit a Point3d, you have to create a new one.
Logged
gile
Gator
Marseille, France
WWW
Re: Point3d X value
Reply #4 on:
May 18, 2015, 04:40:38 PM »
If you really need a mutable point to improve performances* while you make many changes to a point coordinates, you can build a little class where the point coordinates are read/write enabled.
The mutable point type may have explicit cast operators from and to the Point3d type.
Code - C#:
[Select]
using
Autodesk.AutoCAD.Geometry
namespace
MutablePoint
public
class
Point
public
Point
double
x,
double
y,
double
z
this
X
x
this
Y
y
this
Z
z
public
double
X
get
set
public
double
Y
get
set
public
double
Z
get
set
public
void
Add
Vector3d disp
this
X
disp
X
this
Y
disp
Y
this
Z
disp
Z
public
static
explicit
operator
Point
Point3d pt
return
new
Point
pt
X
, pt
Y
, pt
Z
public
static
explicit
operator
Point3d
Point pt
return
new
Point3d
pt
X
, pt
Y
, pt
Z
Using:
Code - C#:
[Select]
Point pt
Point
Point3d
Origin
pt
X
10.0
pt
Y
20.0
Point3d p3d
Point3d
pt
// p3d = (10,20,0)
*mutable objects are more efficient with memory but immutable ones are safer ans easier to use in concurent programming.
Logged
shers
Guest
Re: Point3d X value
Reply #5 on:
May 19, 2015, 01:56:32 AM »
That's great! Thanks very much!
I also would like to know how to assign null value to Point3d, like
Point3d pt = null;
Last Edit: May 19, 2015, 05:16:56 AM by sresh
Logged
gile
Gator
Marseille, France
WWW
Re: Point3d X value
Reply #6 on:
May 19, 2015, 07:16:09 AM »
It looks like you're missing very basics .NET.
As I said upper Point3d is a structure, not a class. Structures are value types and classes are reference type and a structure instance must have a value and cannot be null (see
here
So, you can use a
Nullable type
(Nullable<Point3d> or Point3d?) or use the Point class (as defined upper) instead of Point3d structure.
Anyway, I'm very curious about what kind of stuff you're doing which requires mutable and nullable points...
Logged
ChrisCarlson
Guest
Re: Point3d X value
Reply #7 on:
May 19, 2015, 08:56:59 AM »
:confused: how can a coordinate system contain a null value either in the X,Y,Z or the entire value?
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
.NET
Topic:
Point3d X value
