Author Topic: AutoCAD 2016 regen issue  (Read 2845 times)
Jeff H
« on: May 14, 2015, 12:22:15 PM »
If you run into this
I thought 2016 was regening while working and was getting annoyed but realized it actually resizing the window.
Had to many things open at the bottom and if coordinates were to long would not have enough room and it would resize window, then when coordinates would fit beside paperspace tab at bottom would resize back and was happening every 5 or so seconds.
I just removed some of the settings to show by clicking far right button and unchecking it.
Pic shows where not enough room and moved below model and paperspace tabs
Rob...
Re: AutoCAD 2016 regen issue
« Reply #1 on: May 14, 2015, 12:28:02 PM »
Just curious. What do you use the coords for?
CAD Tech
« Reply #2 on: May 14, 2015, 12:33:05 PM »
I often use those coordinates for quick spot checking of elevations.
ChrisCarlson
« Reply #3 on: May 14, 2015, 12:59:02 PM »
Do you really need all those icons at the bottom?
Matt__W
  • I like my water diluted.
« Reply #4 on: May 14, 2015, 01:11:00 PM »
Mmmmm.... hamburger icon.
Autodesk Expert Elite
« Reply #5 on: May 15, 2015, 08:51:15 AM »
stack of pancakes icon....ymmmmmm
Bethrine
« Reply #6 on: May 15, 2015, 10:12:11 AM »
you two really should eat lunch...and breakfast. Those are shelves.  :lol:
tombu
  • ByLayer=>Not0
« Reply #7 on: May 18, 2015, 08:01:45 AM »
Not a fan of the new status bar!  Hate that clicking the Workspace Switching button now displays the name of the workspace where before that was something you turned off/on.  Only reason for clicking is to switch to another workspace, once you done that a few times you should be able to know what workspace is current by glancing at the screen.  Now we have to click and drag to select a workspace.  The icon now takes more space and is more cumbersome than before.
Tom Beauford P.S.M.
Jeff H
« Reply #8 on: May 19, 2015, 04:54:26 PM »
Sorry just realized I miss replies
Now that you ask me, I don't really ever use them.
Not really.
Rob...
« Reply #9 on: May 20, 2015, 06:35:17 AM »
Not really.
Guess what I'm thinking.
CAD Tech
« Reply #10 on: May 20, 2015, 09:55:30 AM »
Not a fan of the new status bar!  ...
(setvar 'statusbar 0)
