Author Topic: about polyline slice  (Read 12366 times)
andy_lee
Re: about polyline slice
« Reply #15 on: May 19, 2015, 07:55:24 AM »
marko. why?
Enter inside wall width : 10     actual value :20
inside wall height :50
Enter outside wall width : 20        actual value :5
outside wall height :100
andy.
Best regards.
ribarm
  • Marko Ribar, architect
« Reply #16 on: May 19, 2015, 10:34:18 AM »
emk2012, I don't have those problems... Maybe it's because I don't use OSNAPs... Place (setvar 'osmode 0) line right before main code - inside (defun c:walls ( / ... ))
  (defun *error* ( msg )
... here ... (setvar 'osmode 0)
... rest of code ...
  (*error* nil)
M.R.
M.R. on Youtube
ribarm
« Reply #17 on: June 15, 2015, 02:55:13 PM »
I've updated my lisps posted here :
http://www.theswamp.org/index.php?topic=49453.msg546152#msg546152
Minor changes inside LM's outline function...
M.R. on Youtube
AIberto
« Reply #18 on: June 15, 2015, 09:57:30 PM »
Thanks for sharing!
ribarm
« Reply #19 on: June 26, 2015, 05:33:57 AM »
Have found some lacks in walls and walls2d.lsp... Updated all posted routines in this topic...
Regards, M.R.
 :wink:
M.R. on Youtube
ribarm
« Reply #20 on: March 15, 2016, 04:59:22 AM »
I've successfully updated all my walls lisps to be now applicable for latest versions of ACAD... On A2012+ it should operate on all type of 2d curves that lie in WCS (splines+ellipses included) - it uses OFFSETEDGE command... All lisps that have suffix *-old.lsp are intended to be used on versions A2012-... Lisps without suffix "old" are for A2012+...
HTH, M.R.
M.R. on Youtube
