Hi all,
I am totally new to writing programming for AutoCAD and in writing Lisps and Macros etc. I am attempting to write some of my own scripts from tutorials off of the Internet but it is a very slow process. I thought that I'd try for a little 'Freebie' help instead on here
No harm in asking eh? Hopefully, they are both really simple tasks with simple solutions.
Query 1:
I wish to click on a block and have it automatically rotate about it's insert point. The user then clicks on the second rotation point only.
IE 2x clicks of the mouse only. No acceptance click and no base point click. Currently, using standard ACad commands, requires 4x clicks with obs snaps on.
Query 2:
I wish to rotate and then move as a single operation. IE (normal Rotate command) - drag & select the object/s; right click to accept; point and click on base point; click on second rotation point but then..... (normal Move command but with objects remain selected); point and click for base point and then click for second displacement point. No specifics with regards object snapping.
If this request is considered too cheeky, I apologise. Hopefully, for someone who knows what they are doing, it will be a simple five minute task.
Big thanks in advance.
Rroger_D
