Author Topic: AutoCAD 2016 - Coordination Models  (Read 3498 times)
ChrisCarlson
« on: May 11, 2015, 03:50:24 PM »
The help file contains a system variable "CMOSNAP" to enable object snap within coordination models.
My vanilla 2016 AutoCAD throws an unknown variable/command error.
For those running 2016, do you have this system variable?
Matt__W
  • I like my water diluted.
Autodesk Expert Elite
ChrisCarlson
Re: AutoCAD 2016 - Coordination Models
« Reply #2 on: May 11, 2015, 04:15:07 PM »
Thanks, I wonder if they forgot to include it in the installation package?
lamarn
« Reply #3 on: May 12, 2015, 06:08:20 AM »
It was releases after the 2016 release. To help You get to Subscription pages ..
ChrisCarlson
« Reply #4 on: May 12, 2015, 07:44:15 AM »
It couldn't have been purposely released after the 2016 release as the help files were installed during my installation of 2016.
huiz
  • Certified Prof C3D
« Reply #5 on: May 12, 2015, 07:52:29 AM »
Help files are not installed, they are webbased.
« Reply #6 on: May 12, 2015, 08:45:20 AM »
This Feature Update provides a way to specify precise locations on an attached coordination model using the standard 2D endpoint and center object snaps
From the above quote one can infer that they 'forgot' to actually include the parts of cade to make a highly touted feature work in the initial release of the program.
Would not be the first time autodesk advertises or announces a feature; to then have it NOT function as advertised upon release.
One notable to consider; Sheet Set Manager.  The fail: that a single layout can NOT be part of many sets, and that was the major touted benefit of SSM.
For the record it is still broken.
dgorsman
« Reply #7 on: May 12, 2015, 10:17:55 AM »
You could infer that.  You'd be wrong though.  Snapping to coordinate model wasn't intended for the original release but there was a high enough demand for it that it was added later, so as not to delay the entire release for a single feature.
Now back to your regularly scheduled discussion...
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
« Reply #8 on: May 12, 2015, 11:03:51 AM »
YEAH, that's why its called a 'feature update' and NOT  'New Feature' right?
