Hi all,
Block attributes and enhanced attribute text. I have a drawing(s) that have blocks with attributes. I need to change the colors of the text to white. I’m trying to do this in block editor, but I CAN’T change the text. When you double click the text, the Enhanced Attribute Editor will show up, but there’s about 130 of these blocks in the drawing.
How do you globally changed the attribute text globally? I CAN’T use BATTMAN, cause when I do, those blocks don’t show up. So, I’m trying to figure out why I can’t select these blocks in this drawing, and I CAN select others?
Thanks,
