Author Topic: blocks and enhanced attributes text  (Read 3865 times)
GISDUDE
« on: May 11, 2015, 02:46:28 PM »
Hi all,
Block attributes and enhanced attribute text. I have a drawing(s) that have blocks with attributes. I need to change the colors of the text to white. I’m trying to do this in block editor, but I CAN’T change the text. When you double click the text, the Enhanced Attribute Editor will show up, but there’s about 130 of these blocks in the drawing.
How do you globally changed the attribute text globally? I CAN’T use BATTMAN, cause when I do, those blocks don’t show up. So, I’m trying to figure out why I can’t select these blocks in this drawing, and I CAN select others?
Thanks,
Re: blocks and enhanced attributes text
« Reply #1 on: May 11, 2015, 02:51:56 PM »
do NOT double click the text (ATTRIBUTE)
select it (ONE CLICK) edit the properties
SAVE the Block Edits
Perform ATTSYNC
Be done
IF this fails please post copy of the offending block to let us see how or why it is not working as expected.
GISDUDE
« Reply #2 on: May 11, 2015, 04:26:39 PM »
I select the block, go to the properties palette and change color. But I CAN'T select attributes - they don't show up. When I explode the block, the polylines become polylines again, HOWEVER, the text is STILL LISTED as a block.
Strange...
« Last Edit: May 11, 2015, 04:41:44 PM by GISDUDE »
ChrisCarlson
« Reply #3 on: May 11, 2015, 04:43:02 PM »
Was the block inserted, then modified to remove the attribute and not updated in the drawing?
GISDUDE
« Reply #4 on: May 11, 2015, 04:48:48 PM »
@chris: unknown. I got this from the contractor.
How do you "update" the drawing? Seriously, this is weird. After I explode the block, why is the TEXT a block? That tells me whoever made the block, DIDN'T MAKE blocks, but ATTRIBUTES? yes or no?
« Reply #5 on: May 11, 2015, 04:56:37 PM »
don't explode the block
« Reply #6 on: May 11, 2015, 04:59:13 PM »
you have a nested block
someone blocked the attribute into another block...very bad practice
« Reply #7 on: May 11, 2015, 05:10:12 PM »
further they are NOT attributes they are TEXT objects....
IF I insert that block I am not prompted to enter any attribute information....so these must come from some other source
« Reply #8 on: May 11, 2015, 05:11:12 PM »
I think your answer is YES...
« Reply #9 on: May 11, 2015, 05:16:03 PM »
Edit the Block
Re-define the Attribute ANSCHBEZ_1
set it's properties as you desire.
Save the changes to the Block
Perform ATTSYNC
all should be fine
« Last Edit: May 11, 2015, 05:42:14 PM by mjfarrell »
« Reply #10 on: May 11, 2015, 05:16:15 PM »
After a purge, there is only one block in the drawing so no nesting .. I bet the attributes were added programatically.
« Reply #11 on: May 11, 2015, 05:18:25 PM »
I concur with attributes being added by some program
However doesn't exactly explain why they are not within the block definition.
Anyway  they can be changed as stated above.
« Reply #12 on: May 11, 2015, 05:21:19 PM »
Does not work here.
Command: BE
BEDIT
Command: ATTSYNC
This drawing contains no attributed blocks.
« Reply #13 on: May 11, 2015, 05:27:07 PM »
let me make sure I posted lasted...
It's happy now
Also those were instructions taken out of context...
I said one can or should RECREATE the ATTRIBUTE
ANSCHBEZ_1
Thens after closing the block editor and saving those changes one can perform
an ATTSYNC and all should be well.
GISDUDE
« Reply #14 on: May 11, 2015, 05:50:40 PM »
Ok...1.I'm trying to use the BE command, but "BE command not allowed. Block Editor is disabled." WTF? Is this a permissions thing?
2. When I DOUBLE-CLICK the block, I can't get to the attributes. The block only shows up. If I double click the text, then I can change the color in the Enhanced Attribute dialog, but I'm still at a loss on how to globally change the attributes.
Super frustrating...FWIW, I think these drawings are from the mid-90's...meaning they've been used since then and re-used mulitple times.
