Author Topic: Problem by boundary between blocks  (Read 33895 times)
francinez
Re: Problem by boundary between blocks
« Reply #45 on: May 22, 2015, 09:22:50 AM »
Do you know a way to override this problem? I need a approximativ contour that is possible to hatch
« Reply #46 on: May 22, 2015, 10:15:49 AM »
not sure if you will be 'allowed' to do this; as I do not know the intended purpose of your drawings
however this appeared to work, and the 'solution' may require this to be done to different components for differing assemblies
However what I did;
set hpgaptol back to 0
took the two outside components, and used the midpoint of that little line @ center of the feature as a base point I scaled the component 1.00000001
this was enough to allow the hatch operation to proceed normally
If yours are not drawings used to manufacture this item it should not cause any harm
« Reply #47 on: May 22, 2015, 10:18:51 AM »
one could even resort to  NON ASSOCIATIVE Hatch boundary....
offset your features something like 0.0000001
HATCH
then delete the offset objects
francinez
« Reply #48 on: May 22, 2015, 11:17:54 AM »
Thank you for your help, I will test your proposition next week.
