Author Topic: Problem by boundary between blocks  (Read 20087 times)
Re: Problem by boundary between blocks
« Reply #30 on: May 08, 2015, 12:37:00 PM »
Still makes no sense that it works for me on 3 different versions of AutoCAD.
you're special that way
Not as special as you...
Windows 10 x64 - AutoCAD /C3D 2020
« Reply #31 on: May 08, 2015, 12:38:59 PM »
no you're speacial
« Reply #32 on: May 08, 2015, 12:41:52 PM »
no you're speacial
Your spelling is special  ;D
francinez
  • Mosquito
« Reply #33 on: May 11, 2015, 07:45:43 AM »
Hello everybody,
Many thank for all your answers, I have tested your proposition, some works but I have to find I way to do it more systematic.
Regards
Francine
« Reply #34 on: May 11, 2015, 10:06:41 AM »
How are you generating those cut sections of what appears to be a metal curtain wall assembly? (Extruded Aluminum Sections)
So I must ask where are those extrusions coming from?  Inventor or other?
The 'problem' is originating there...as it is creating sections that are not in the same plane, thus the need to flatten them to get hatch to work properly.
« Last Edit: May 11, 2015, 10:36:58 AM by mjfarrell »
francinez
  • Mosquito
« Reply #35 on: May 11, 2015, 10:35:05 AM »
Yes these are aluminum profiles rolled with thermalbreak, we get about 200 drawing (dwg files) from the supplier.
So I will check all those drawings.
Many thank
« Reply #36 on: May 11, 2015, 10:38:53 AM »
Many thank
I would ask them what software is being used to generate those sections?
Could be there is a better export method to give you the sections in a more 2d format for your needs.
francinez
  • Mosquito
« Reply #37 on: May 21, 2015, 11:28:32 AM »
Hello,
I put everything to Z=0 but I can't boundary this internal part...Have somebody a solution?
Best regards
Rob...
« Reply #38 on: May 21, 2015, 11:41:48 AM »
Okay, there was a lot of discussion here that suggested the issue may be related to using a vertical product. What flavor of AutoCAD are you using? Look into setting up as vanilla CAD and see if the hatch will work.
CAD Tech
« Reply #39 on: May 21, 2015, 11:56:38 AM »
Use pick internal point option:
Command: HATCH
Select objects or [picK internal point/Undo/seTtings]:
If you have trouble with some boundaries not being defined, look at upping the HPGAPTOL variable.
Welcome to TheSwamp :)
Man I had someone bitching that I used hatches for ceiling grids, until I showed them with HPORIGINMODE, HPGAPTOL, HPBOUNDRETAIN, was 10 times faster and also saved bunch time in Agi32 using closed polylines to create areas.
« Reply #40 on: May 21, 2015, 12:28:22 PM »
Hello,
Best regards
use flatten instead...and if these are blocks as last time...go into block editor and flatten the objects there as well
« Reply #41 on: May 21, 2015, 12:31:48 PM »
zoom in to limit number of objects on screen...
HPGAPTOL set to 500
Pick internal point = success
Also Island detection set to NORMAL
« Last Edit: May 21, 2015, 12:53:52 PM by mjfarrell »
francinez
  • Mosquito
« Reply #42 on: May 22, 2015, 04:33:31 AM »
Hello,
Yesterday a put the HPGAPTOL to 5000, it doesn't work....today I change the HPGAPTOL to 500 and it works ....I understand nothing...
Is it coming from the Island detection?
I am working with Autocad 2013!
Best regards
francinez
  • Mosquito
« Reply #43 on: May 22, 2015, 05:05:01 AM »
I understand nothing: boundary doesn't work, than I zoom in out sometime and now bounday works. it is totally crazy
« Reply #44 on: May 22, 2015, 09:02:17 AM »
I think it really has to do with the complexity of the geometry....
crazy I know...
because of the fit tolerances of those parts they fit...to the point of almost NOT touching even where they technically do touch, but only at a very small point.
