Author Topic: Problem by boundary between blocks  (Read 22154 times)
francinez
  • Mosquito
« on: May 08, 2015, 09:42:01 AM »
I have problem by doing a boundary in the center of those 4 blocks (attached dwg), I have to hatch this area.
Have somebody an idee how to resolve this problem?
The solution that I use actually is to explode everything, make a polyline and do the hatch.
Many thank for your help
Francine
Re: Problem by boundary between blocks
« Reply #1 on: May 08, 2015, 10:15:51 AM »
Use pick internal point option:
Command: HATCH
Select objects or [picK internal point/Undo/seTtings]:
If you have trouble with some boundaries not being defined, look at upping the HPGAPTOL variable.
Welcome to TheSwamp :)
Windows 10 x64 - AutoCAD /C3D 2020
Rob...
« Reply #2 on: May 08, 2015, 10:18:55 AM »
I couldn't get a valid boundary with pick point even after changing the gap setting.
CAD Tech
« Reply #3 on: May 08, 2015, 10:21:06 AM »
What version of CAD are you on? It worked for me with HPGAPTOL set to 0 and 1.
francinez
  • Mosquito
« Reply #4 on: May 08, 2015, 10:27:47 AM »
I tested the hatch command after setting HPGAPTOL to max: 5000 (Autocad 2013) and I get an error message: A closed boundary could not be determined.
Is something wrong with the blocks?
Rob...
« Reply #5 on: May 08, 2015, 10:36:48 AM »
Same here on MEP 2014.
CAD Tech
Rob...
« Reply #6 on: May 08, 2015, 10:47:53 AM »
ron, when I open your file, I see your hatch fine in the preview, but after opening, it changes to this.
CAD Tech
« Reply #7 on: May 08, 2015, 11:09:54 AM »
Works without a hitch on 2016.
Rob...
« Reply #8 on: May 08, 2015, 11:15:18 AM »
I don't doubt it but when I open it, the hatch changes. We still don't know what version the OP is using. I wonder if something was fixed with hatches. It will be a while before I can test it in 2016.
CAD Tech
« Reply #9 on: May 08, 2015, 11:26:40 AM »
OK the issue is that the geometry is somehow 3d and not parallel with the world UCS
To RESOLVE
Opened each BLOCK in block editor
Closed the open polyline(s)
used FLATTEN command without hidden line removal
Saved changes to block and hatch then worked as expected.
« Reply #10 on: May 08, 2015, 11:33:53 AM »
Rob...
« Reply #11 on: May 08, 2015, 11:34:48 AM »
Just like selecting objects, it doesn't work here.
CAD Tech
« Reply #12 on: May 08, 2015, 11:36:32 AM »
did you flatten all the geometry in all the blocks.???..there are at least three (3) different blocks in that assembly.
« Reply #13 on: May 08, 2015, 11:38:03 AM »
Rob...
« Reply #14 on: May 08, 2015, 11:38:51 AM »
It doesn't work.
CAD Tech
