Author Topic: Problem by boundary between blocks  (Read 36723 times)
Re: Problem by boundary between blocks
« Reply #15 on: May 08, 2015, 11:39:27 AM »
It's not a version issue .. works fine for me in AutoCAD 2009. Must be a variable I set in the background to maintain consistency.
« Last Edit: May 08, 2015, 11:42:30 AM by ronjonp »
« Reply #16 on: May 08, 2015, 11:43:27 AM »
works here after flattening the geometry inside those blocks...and hpgaptol is jack up to 5000 (?) v2014
« Reply #17 on: May 08, 2015, 11:48:45 AM »
LOL .. it even works in AutoCAD 14 for me....
Rob...
« Reply #18 on: May 08, 2015, 11:52:36 AM »
I wonder what setting it is.
CAD Tech
« Reply #19 on: May 08, 2015, 11:54:38 AM »
Well it's not HPGAPTOL since that was introduced in 2005 :)
Rob...
« Reply #20 on: May 08, 2015, 11:58:22 AM »
I don't do much hatching and I've got a fairly fresh install so they should all be OOTB defaults. Maybe it's something to do with the MEP stuff. On the other hand, we still haven't heard back from the OP.
CAD Tech
« Reply #21 on: May 08, 2015, 12:07:40 PM »
Dumb question but .. is everything visible in the screen when picking the internal point? I can only replicate the issue when I zoom into a corner and pick.
« Reply #22 on: May 08, 2015, 12:14:49 PM »
it occurred hear even with everything visible
hmm might this point to TREEDEPTH being set differently? DEFAULT 3020 set here
Rob...
« Reply #23 on: May 08, 2015, 12:18:55 PM »
Yes, everything is visible. Don't forget that when I opened your drawing with the hatch, it changed.
CAD Tech
« Reply #24 on: May 08, 2015, 12:21:08 PM »
What happens when you open this one?
Rob...
« Reply #25 on: May 08, 2015, 12:23:51 PM »
Same exact thing
CAD Tech
« Reply #26 on: May 08, 2015, 12:26:46 PM »
I'm out of ideas *shrug*
« Reply #27 on: May 08, 2015, 12:27:55 PM »
first I deleted your Hatch area (it was fine)
then I attempt to hatch see attachments below
Error Message
Then Resultant
Edit blocks
Flatten the geometry
Hatch works fine
« Reply #28 on: May 08, 2015, 12:32:16 PM »
Still makes no sense that it works for me on 3 different versions of AutoCAD.
« Reply #29 on: May 08, 2015, 12:33:25 PM »
you're special that way
