Maybe it is possible to create a CUIx?A dialog can be always on top but if you switch to Word or another application the dialog is still visible.
Meh. I've got much more difficult things to deal with than pictures vs. text. Gotta be flexible, no telling what the software is going to look like in a couple of years or which other software will be required to use.Make a CUIx with command definitions. Then you can dump those to toolbar, menu, or my first preference - a Ribbon panel. Tear off the panel and use it as a super-toolbar. Problem solved, on to the next.
ribbon is crap
Whats the issue with the status bar?
A good fix would be to learn the keyboard shortcuts of each status bar button and set statusbar variable to 0
You could use a keyboard overlay with the text variants.
(setvar 'modemacro "$(if,$(=,$(getvar,gridmode),1),\"GRID | \",\"\")$(if,$(<,$(getvar,osmode),16384),\"OSNAP | \",\"\")$(if,$(=,$(getvar,orthomode),1),\"ORTHO | \",\"\")")
