Author Topic: PDF  (Read 26060 times)
Bethrine
Re: PDF
« Reply #30 on: May 06, 2015, 01:50:26 PM »
So, have you tried the full bleed paper size?
Yes.
Rob...
Re: PDF
« Reply #31 on: May 06, 2015, 01:52:05 PM »
Why have two sets of margins? The title block already plots within the margins of the plotter. Get rid of the margin issue in the paper size. Problem solved.
CAD Tech
Bethrine
Re: PDF
« Reply #32 on: May 06, 2015, 01:56:25 PM »
I have not changed any default settings for any ANSI sizes. The margins for the full bleed plot to pdf are default. If I make a change I do it under custom paper sizes and label it with my initials.
Bethrine
Re: PDF
« Reply #33 on: May 06, 2015, 01:58:06 PM »
that .03 is default. I've only pulled it up for reference.
Re: PDF
« Reply #34 on: May 06, 2015, 02:00:13 PM »
I'm having trouble figuring out what we are trying to solve now.
Rob...
Re: PDF
« Reply #35 on: May 06, 2015, 02:01:05 PM »
It was a rhetorical question not really directed at you.
Does the PDF print properly with the full bleed paper size?
CAD Tech
Bethrine
Re: PDF
« Reply #36 on: May 06, 2015, 02:04:08 PM »
No. It does print the whole thing but the margins are tiny at the bottom left and very wide up top and right. On the regular paper it cuts off the top and right lines. I think mj is close...I would like to center it on regular paper so I don't have to explain what I did, it just looks and prints correct. I'm still "green" here.
Bethrine
Re: PDF
« Reply #37 on: May 06, 2015, 02:05:16 PM »
lol...I'm going back and forth myself. I have to keep all of this straight or my settings will end up very confusing.  :-D
Re: PDF
« Reply #38 on: May 06, 2015, 02:06:46 PM »
I get it now .. look at your Plot offset numbers in the lower left corner .. they should not be zeroes unless you have something defining the full extents of the paper. I personally plot to 'extents' then check the option 'center the plot'.
Bethrine
Re: PDF
« Reply #39 on: May 06, 2015, 02:07:39 PM »
and what you got going on here?
Shouldn't I be able to change the default output device in options? that's just what will automatically pop up when I go to plot unless I change it, isn't it? The other is the same as your pic, mj.
Bethrine
Re: PDF
« Reply #40 on: May 06, 2015, 02:08:28 PM »
of the pdf?
Re: PDF
« Reply #41 on: May 06, 2015, 02:10:01 PM »
of the pdf?
Re: PDF
« Reply #42 on: May 06, 2015, 02:19:55 PM »
actually the plot offset number should be zeros....
IF you have set your title block/border and inked area limits correctly...or you are using some b@stard printer that forces you to use an offset
however typically for PDF NO offsets are required
Re: PDF
« Reply #43 on: May 06, 2015, 02:26:02 PM »
keep in mind that 0,0 in paperspace can be (should be) intersection of printable area...or if you cant do that mathedge of paper check in  options
in my world I find printable area easier to use than edge of paper....create your border block accordingly...
and expect some shifting to occur when you set your named page setup current....
Re: PDF
« Reply #44 on: May 06, 2015, 02:26:14 PM »
Exactly .. me thinks this is not the case. The example you provided does not either if you 'Apply to Layout'.
