Author Topic: PDF  (Read 26017 times)
Bethrine
Re: PDF
« Reply #15 on: May 06, 2015, 01:01:16 PM »
Did I mention that the current settings print perfectly on our printer? Those same settings do NOT work to print OR export to PDF with the driver I am using (see pics in previous posts).
...attempting mj's latest advice...
Bethrine
Re: PDF
« Reply #16 on: May 06, 2015, 01:02:37 PM »
« Last Edit: May 06, 2015, 01:16:50 PM by Bethrine »
Bethrine
Re: PDF
« Reply #17 on: May 06, 2015, 01:08:21 PM »
Re-opened the dwg. Dashed line is back.
Re: PDF
« Reply #18 on: May 06, 2015, 01:16:46 PM »
see attached
Bethrine
Re: PDF
« Reply #19 on: May 06, 2015, 01:20:07 PM »
Prints fine to printer. This is what I get in the PDF.
 (11X17) default settings
Re: PDF
« Reply #20 on: May 06, 2015, 01:25:36 PM »
check your printable area....it should .5 all around
Bethrine
Re: PDF
« Reply #21 on: May 06, 2015, 01:26:48 PM »
I did not change any settings. I just plotted mj's drawing:
« Last Edit: May 06, 2015, 01:33:42 PM by Bethrine »
Re: PDF
« Reply #22 on: May 06, 2015, 01:38:30 PM »
Why don't you post a sample drawing with your titleblock in it?
Re: PDF
« Reply #23 on: May 06, 2015, 01:40:17 PM »
did you set the page setup current?
in the clip posted it says NONE
it should have the one I made set current
Bethrine
Re: PDF
« Reply #24 on: May 06, 2015, 01:42:07 PM »
double checking.
That is not 1 : 1...?
Bethrine
Re: PDF
« Reply #25 on: May 06, 2015, 01:43:50 PM »
I can but I have to get all info out of it (confidentiality clause) and I am uncertain how to accomplish that without missing something.  :cry:
Re: PDF
« Reply #26 on: May 06, 2015, 01:44:10 PM »
and what you got going on here?
Rob...
Re: PDF
« Reply #27 on: May 06, 2015, 01:45:31 PM »
So, have you tried the full bleed paper size?
CAD Tech
Re: PDF
« Reply #28 on: May 06, 2015, 01:45:39 PM »
double checking.
dont sweat that at this point
Re: PDF
« Reply #29 on: May 06, 2015, 01:48:29 PM »
respectfully "Full Bleed" is a red herring....
In all my years plotting from autocad starting in 1984 no printer I have ever needed to configure for
was ever capable of "FULL BLEED" , nor has any place I worked for set their title blocks up to place a dark black line at the extreme edge of the paper.
I would go so far as to say that EVERY plot I have ever done has ha a margin.
