Author Topic: menuload/unload help please  (Read 3383 times)
Pad
« on: May 05, 2015, 04:04:40 PM »
Hi
I have some software that runs within autocad.  It is dongle protected. Everything works fine when its dongle is plugged in, but it is not possible to run autocad without the dongle.  A screen pops up warning of the absent dongle and autocad locks up.  If the menu for the software is unloaded then autocad will start fine. So I am trying to make a lisp that will unload the menu if loaded and vice versa.  If all works to plan then I can run the lisp before shutting down autocad to remove the menu and run the lisp when I have he dongle and want to make use of it.
Here is what I have, but its not working:
(defun C:ktfa (/)
(if (null ((menugroup "KEY")))
(command "menuload" "C:\Users\Metrix_PB\AppData\Roaming\Key\support\key.cuix")  ; i have also tried this with \\
(command "_MENUUNLOAD" "KEY")
Any help will be appreciated.
Pad
Re: menuload/unload help please
« Reply #1 on: May 05, 2015, 04:09:46 PM »
Actually scrap that, the menu loaded or unloaded doesnt make any difference, I thought it did.
I'll have to find some other way to stop the software loading.
P
stusic
« Reply #2 on: May 05, 2015, 04:15:29 PM »
Try looking for any support apps that load with it, like arx files...
Pad
« Reply #3 on: May 05, 2015, 04:31:37 PM »
Hi Stusic,  I few arxs get loaded, I'll look into that.  Thanks
Rob...
« Reply #4 on: May 05, 2015, 06:34:38 PM »
Will it work if you create a different shortcut for when you want to work without the dongle?
Have the 2nd shortcut point to a profile that does not load the menu using.
CAD Tech
Pad
« Reply #5 on: May 05, 2015, 07:23:39 PM »
Yeah, that could work.  I'll give it a go. Thanks.
Rob...
« Reply #6 on: May 05, 2015, 07:47:13 PM »
Do you know about the profile switch in the shortcut target?
CAD Tech
Pad
« Reply #7 on: May 06, 2015, 05:18:52 AM »
Yeah I should be able to figure that out.
Thanks.
Sorry, Ive just realised I posted this thread in the wrong forum..
ChrisCarlson
« Reply #8 on: May 07, 2015, 04:13:37 PM »
On a side note, I'm curious what "dongle protected" menus are?
dgorsman
« Reply #9 on: May 08, 2015, 10:07:58 AM »
I think that means the supporting program uses a local hardware lock.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
