Author Topic: Change Layer Linetype LISP  (Read 6668 times)
mdvynld85
« on: April 30, 2015, 07:34:15 PM »
Hello,
I've been looking, with no luck, for a lisp that can quickly change a layers linetype without having to open the layer properties box.  I would like to select an object and then be able to change the linetype of the layer by selecting from a list of the linetypes loaded within the drawing.  It would be awesome if it could also work with objects within xrefs.
Any guidance would be appreciated - Thanks   :-)
-Kique-
dgorsman
Re: Change Layer Linetype LISP
« Reply #1 on: April 30, 2015, 08:03:07 PM »
Where are you getting stuck?  You've already outlined the basic process:
  • Pick an object (check for actual pick)
  • Get layer of object
  • Provide user list of linetypes (check for OK/cancel)
  • Modify layer setting
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
mdvynld85
« Reply #2 on: May 01, 2015, 01:50:15 PM »
Yes I have the process for what I want it to do but I haven't been able to put together a lisp (I'm new to this) or find one that does that.
With the lisp I have below I'm able to enter the name of the linetype I want to use and then select the object.  It only changes the linetype of the object itself and not the layer and it doesn't work for xrefs.  It's close to what I'm looking for but not exactly.  (I found the lisp here: http://www.autolisp.com/forum/threads/774-linetype-change)
(defun c:LtChange (/ lt fnd s i sn name blocks)
  (if (not acdoc)
    (setq acdoc (vla-get-activedocument (vlax-get-acad-object)))
  (if (and (not (eq (setq lt (getstring "\n Specify lineType :")) ""))
           (setq fnd (tblsearch "LTYPE" lt))
           (setq s (ssget "_:L"))
    (repeat (setq i (sslength s))
      (setq sn (ssname s (setq i (1- i))))
      (if (not (eq (cdr (assoc 0 (entget sn))) "INSERT"))
        (vla-put-linetype (vlax-ename->vla-object sn) lt)
          (not (member (setq name (cdr (assoc 2 (entget sn)))) blocks)
             (setq blocks (cons name blocks))
             (vlax-for each (vla-item (vla-get-blocks acdoc) name)
               (vla-put-linetype each lt)
    (cond ((not lt) (princ "\n LineType is nil "))
          ((not fnd)
           (princ "\n Couldn't find the Linetype or not loaded ")
          (t (princ "\n Nothing has been Selected"))
  (vla-regen acdoc AcallViewports)
alanjt
  • Standby for witty remark...
« Reply #3 on: May 01, 2015, 02:30:57 PM »
Here's two I wrote long ago that I use quite often. DosLib is needed for the linetype one.
(defun c:CLC (/ ss color i layer lst)
  ;; Change color of selected objects' layer
  ;; Alan J. Thompson, 07.23.09 / 05.16.11 / 2014.05.21
  (if (and (setq ss (ssget))
           (setq color (acad_colordlg
                         (if (eq (sslength ss) 1)
                           (cdr (assoc 62 (tblsearch "LAYER" (cdr (assoc 8 (entget (ssname ss 0)))))))
                           1
                         nil
    (repeat (setq i (sslength ss))
      (if (not (member (setq layer (cdr (assoc 8 (entget (ssname ss (setq i (1- i))))))) lst))
        (vla-put-color
          (vlax-ename->vla-object (tblobjname "LAYER" (car (setq lst (cons layer lst)))))
          color
(defun c:CLL (/ ss linetype i layer lst)
  ;; Change linetype of selected objects' layer
  ;; DosLib required (dos_linetypebox)
  ;; Alan J. Thompson, 05.16.11
  (if dos_linetypebox
    (if (and (setq ss (ssget)) (setq linetype (dos_linetypebox)))
          (vla-put-linetype
            linetype
    (progn (alert "DosLib must be loaded!")
           (command "_.browser" "http://www.en.na.mcneel.com/doslib.htm")
Dropbox
irneb
« Reply #4 on: May 02, 2015, 05:14:40 AM »
For that you'd need to be able to select the nested object. I.e. instead of ssget you'd use nentsel.
alanjt
« Reply #5 on: May 04, 2015, 08:51:20 AM »
Completely overlooked that part.
Here's one I posted a few years ago: http://www.theswamp.org/index.php?topic=32277.0
Dropbox
mdvynld85
« Reply #6 on: May 04, 2015, 10:09:13 AM »
The cll lisp is exactly what I was looking for.  I have never used anything with DosLib, definitely want to learn more about it.
Thank you so much for the help alanjt!  :-)
alanjt
« Reply #7 on: May 04, 2015, 10:15:43 AM »
You're welcome. :)
Dropbox
