Author Topic: Code too slow  (Read 6079 times)
ymg
Re: Code too slow
« Reply #15 on: May 01, 2015, 06:09:43 AM »
Lupo,
Maybe it could be faster if instead of creating Selection Set,
you creates List of "Entity Names".
ymg
roy_043
  • BricsCAD 18
Re: Code too slow
« Reply #16 on: May 01, 2015, 06:46:14 AM »
@ Lupo76:
Maybe using (vla-getxrecorddata) is faster than using (entget)?
But to get an 'instantaneous' selection set you should try ronjonp's advice in post #5: Create additional registered apps.
Note:
In BricsCAD you will not have this issue because you can create an ssget filter using values inside Xdata.
This works in BicsCAD:
(ssget "_X" '((-3 ("NOMEMYAPP" (1000 . "TIPOOGG=MARCATURA")))))
(ssget "_X" '((-3 ("NOMEMYAPP" (1000 . "IDFERRO=DEFAULT_*")))))
Re: Code too slow
« Reply #17 on: May 01, 2015, 09:05:35 AM »
1. Rewrite the application to use a new structure of xdata, allowing higher speed when creating selection sets
2. After starting the application, if a user opens a DWG file that contains the old structure of xdata, starts a function that converts it like new.
http://www.theswamp.org/index.php?action=post;quote=544774;topic=49383.0;last_msg=544845
Marc'Antonio Alessi
  • Marco
Re: Code too slow
« Reply #18 on: May 01, 2015, 10:27:23 AM »
Lupo,
ymg
CAB code do that:
 >>> (setq result (cons ent result))
Lupo76
Re: Code too slow
« Reply #19 on: May 01, 2015, 11:27:08 AM »
I did some more extensive tests.
Unfortunately I discovered that the slowness is not determined only by the group of selection, but also from the code that handles it later.
With your advice I managed to speed up the creation of group selection.
I also tried the way of the List of "Entity Names".
But now I have to check out the rest of the code.
There is a strange thing though ... to test the speed of the code I inserted between rows, some (princ "\nX"), where "X" is a sequential number.
At a certain point in the code I have inserted the following two lines, one after the other
(princ "\n5")
(princ "\n6")
The number 5 appears immediately, while the number 6 has a delay of about 1 ".
This is very strange if I consider that between (princ "\n5") and (princ "\n6"), there is no code!  :-o
Re: Code too slow
« Reply #20 on: May 01, 2015, 11:32:01 AM »
What CAD program are you using?
Non Autodesk DWG.  This DWG file was saved by a software application that was not developed or licensed by Autodesk.  Autodesk cannot guarantee the application compatibility or integrity of this file.
Lupo76
Re: Code too slow
« Reply #21 on: May 01, 2015, 11:34:25 AM »
BricsCAD V15, however, the application must also be compatible with AutoCAD
Marc'Antonio Alessi
  • Marco
Re: Code too slow
« Reply #22 on: May 01, 2015, 01:00:02 PM »
Lupo,
I advise you to review the structure of the xdata, in particular the meaning of a value should not be the contents of a string but the position or sequence of the pair in the structure
  (-3
         "EMILISPCA"
         (1000 . "TIPOOGG=FERRO")
         (1000 . "IDFERRO=DEFAULT_1")
         (1000 . "TIPOFERRO=ESPLOSO")
         (1011 118.650976974287 -84.5345340970474 0.0)
         (1011 128.650976974287 -84.5345340970474 0.0)
         (1011 118.650976974287 -74.5345340970474 0.0)
         (1040 . 1.0)
  (-3
         "EMILISPCA"
         (1000 . "FERRO")
         (1000 . "DEFAULT_1")
         (1000 . "ESPLOSO")
         (1040 . 1.0)
[code]
So:
1° assoc 1000 > TIPOOGG
2° assoc 1000 > IDFERRO
3° assoc 1000 > TIPOFERRO
roy_043
  • BricsCAD 18
Re: Code too slow
« Reply #23 on: May 01, 2015, 02:35:31 PM »
Regarding the formatting of the xdata I would go a bit further than Marc'Antonio's suggestion:
http://www.theswamp.org/index.php?topic=48868.msg540029#msg540029
Marc'Antonio Alessi
  • Marco
Re: Code too slow
« Reply #24 on: May 02, 2015, 04:14:56 AM »
Many years ago I had a program  (2d reinforced concrete beams, now abandoned) similar to Lupo's, this is an example of storing information with xdata
  (-3
         "2DBEAM_PIL"
         (1002 . "{")
         (1002 . "{")
         (1005 . "418")
         (1070 . 3)
         (1040 . 5.0)
         (1011 252.703096126625 194.012274842227 0.0)
         (1040 . 80.0)
         (1040 . 60.0)
         (1040 . 55.0)
         (1000 . "B")
         (1002 . "}")
         (1002 . "{")
         (1040 . 270.0)
         (1040 . 270.0)
         (1040 . 300.0)
         (1002 . "}")
         (1002 . "{")
         (1040 . 40.0)
         (1040 . 25.0)
         (1040 . 25.0)
         (1040 . 25.0)
         (1002 . "}")
         (1002 . "{")
         (1040 . 15.0)
         (1040 . 10.0)
         (1040 . 15.0)
         (1040 . 15.0)
         (1002 . "}")
         (1002 . "}")
  (-3
         "2DBEAM_FER"
         (1002 . "{")
         (1005 . "425")
         (1005 . "418")
         (1000 . "LTot")
         (1000 . "P00FerPil")
         (1002 . "}")
Jeff H
Re: Code too slow
« Reply #25 on: May 02, 2015, 05:27:59 PM »
