Are you saying everything to should work the same across all the platforms? lol
No I'm saying that PIPES in ALL Autodesk Products should work, and secondly should at least work similarly, as good as, or better than
PIPES in any other Autodesk product...such that IF a PIPES function is available in an application that it works sufficiently to actually model PIPES.
And if there is then some other product purported to be for a particular industry and it too offers a PIPES function it then should work better than
the other application that is not industry focused.
