This is what I was looking for.
found it in help under select objects in the drawing area.
now to figure out how to bind and purge
[CommandMethod("SelectObjectsOnscreen")]
public static void SelectObjectsOnscreen()
// Get the current document and database
Document acDoc = Application.DocumentManager.MdiActiveDocument;
Database acCurDb = acDoc.Database;
// Start a transaction
using (Transaction acTrans = acCurDb.TransactionManager.StartTransaction())
// Request for objects to be selected in the drawing area
PromptSelectionResult acSSPrompt = acDoc.Editor.GetSelection();
// If the prompt status is OK, objects were selected
if (acSSPrompt.Status == PromptStatus.OK)
SelectionSet acSSet = acSSPrompt.Value;
// Step through the objects in the selection set
foreach (SelectedObject acSSObj in acSSet)
// Check to make sure a valid SelectedObject object was returned
if (acSSObj != null)
// Open the selected object for write
Entity acEnt = acTrans.GetObject(acSSObj.ObjectId,
OpenMode.ForWrite) as Entity;
if (acEnt != null)
// Change the object's color to Green
acEnt.ColorIndex = 3;
// Save the new object to the database
acTrans.Commit();
// Dispose of the transaction
