of all the times I have exported MAP to DWG I have never seen the wizard...ever
and NOW I know why.....I use MAP inside C3D....
However IF I launch MAP from Programs>>>Autodesk>>>Map ver Num.....THEN I do get the Wizard
so like WOW one MUST be in MAP for the MAP Wizard to appear!!!!!!
because you know, MAP inside C3D isn't really MAP! (I guess???) :uglystupid2:autodesk
