Author Topic: Missing the Wizard  (Read 7723 times)
Missing the Wizard
« on: April 24, 2015, 09:10:30 AM »
According to the Help ....
To Export Maps to AutoCAD
3. Click Output tabMap Data Transfer panelSave Current Map To AutoCAD.   Find
4. In the Save Current Map To AutoCAD wizard, do the following:
I can no longer see the 'wizard'. *shrug*
anyone know why?
Re: Missing the Wizard
« Reply #1 on: April 24, 2015, 09:15:47 AM »
is it this command?
 _AeccExportToSDF
« Reply #2 on: April 24, 2015, 09:18:40 AM »
is it this command?
 _AeccExportToSDF
nope! its _mapexportcurrentmaptodwg
« Reply #3 on: April 24, 2015, 09:24:34 AM »
ah...._mapexportcurrentmaptodwg
I don't get any WIZARD either  I don't think it actually exists...sort of like "The Wizard of Oz"  there is no wizard
let me see if there is some other way to summon this reluctant wizard...
interesting and notable NO image of this 'wizard' is shown on help file pages....hmmmm
« Reply #4 on: April 24, 2015, 09:27:34 AM »
oh but it does! I have seen the mighty wizard.
« Reply #5 on: April 24, 2015, 10:27:20 AM »
of all the times I have exported MAP to DWG I have never seen the wizard...ever
« Reply #6 on: April 24, 2015, 10:31:09 AM »
and NOW I know why.....I use MAP inside C3D....
However IF I launch MAP from Programs>>>Autodesk>>>Map ver Num.....THEN I do get the Wizard
so like WOW  one MUST be in MAP for the MAP Wizard to appear!!!!!!
because you know, MAP inside C3D isn't really MAP! (I guess???)   :uglystupid2:autodesk :idiot2:
« Reply #7 on: April 24, 2015, 10:39:31 AM »
LOL
i was just going to try the very same thing.
« Reply #8 on: April 24, 2015, 10:58:43 AM »
LOL
did I ever say how much I love autodesk???      :tickedoff:   :tickedoff:  :tickedoff:  :tickedoff:  :tickedoff:  :tickedoff:  :tickedoff:
huiz
  • Certified Prof C3D
« Reply #9 on: April 24, 2015, 11:12:00 AM »
It will work in Civil 3D if you add the support map of Map to the search path. Autodesk forgot that.
« Reply #10 on: April 24, 2015, 11:20:54 AM »
Which one?
« Reply #11 on: April 24, 2015, 11:23:55 AM »
just add all of them for good measure...
« Reply #12 on: April 24, 2015, 11:36:23 AM »
What you see is what I have already. Where are the others?
« Reply #13 on: April 24, 2015, 11:41:31 AM »
here are the paths from MAP
« Reply #14 on: April 24, 2015, 12:04:57 PM »
Be aware that you are using differing builds of Map.
