Author Topic: Uggg.. Plotting to TIFFs  (Read 1912 times)
DIW_CADtech
  • Push limits, embrace success, & discard failure.
« on: April 22, 2015, 02:12:06 PM »
Uhhhggg
Have a client that is requesting that we not only issue a DWG file and a PDF, but now a TIFF as well.  Is there any really good DWG_to_TIFF drivers out there, so I can publish instead of manually exporting TIFFs from PDF?
or
is there a drag and drop method to output quality TIFFs from PDF's
Most of the time we do this it's one or two PDF's to convert, but I'm looking at doing 300 per project.  I'd like to find a way to automate this.
I am very  trainable....   (forgive my spelling)
ChrisCarlson
Re: Uggg.. Plotting to TIFFs
« Reply #1 on: April 22, 2015, 02:13:40 PM »
I'm not sure of your software but we utilize KIP. A program called KIP Request can convert PDF to Tiff per directory in a batch-esque process.
DIW_CADtech
« Reply #2 on: April 22, 2015, 02:19:39 PM »
Can you be more specific, what I am finding online is some software that seems to be related to Printer Management.
Is there a full software title or a webpage listed in the help or the About for the software you are using?
« Reply #3 on: April 22, 2015, 02:46:55 PM »
« Reply #4 on: April 22, 2015, 02:47:09 PM »
Maybe Convert PDF with this?
« Reply #5 on: April 22, 2015, 02:49:15 PM »
You can create a TIFF plotter in CAD .. but IMO it would be faster to convert the existing PDF's.
Not free but we use Bluebeam Revu and it's a helluva editor. :)
rkmcswain
« Reply #6 on: April 22, 2015, 03:27:35 PM »
Not that this necessarily helps you any, but we would use Oce Direct Print Pro to do it with software, or in case that was N/A or failed, I would just have someone scan the printed drawings to TIF.
A few people have Bluebeam also, so I suppose they could use that.
DIW_CADtech
« Reply #7 on: April 22, 2015, 03:57:38 PM »
I'm liking the look and feel of
http://www.print-driver.com/download
but the client currently has their tiffs in the CCITT T.6 compression (monochrome)
not seeing an option for that in the software.. sent an email to support to find out what is (standard) with the software.
DIW_CADtech
« Reply #8 on: April 22, 2015, 04:05:25 PM »
I'm sure CCITT T.4 (monochrome) is acceptable.  Just need to find out what the software actually provides.
cadtag
« Reply #9 on: April 22, 2015, 04:31:59 PM »
IIRC, the CALs plotters, listed in PlotterManager under Raster file formats, are TIF files with a .cal extension.  Might be worth a shot...
danallen
« Reply #10 on: April 23, 2015, 12:07:41 AM »
Try ImageMagick http://www.imagemagick.org/
I used to once to split large image into multiple tiles, seems very powerful and runs from command line. Quick search came up with:
http://www.ehow.com/how_5148734_convert-pdf-tiff-using-imagemagick.html
http://www.imagemagick.org/discourse-server/viewtopic.php?t=14669
RONR
  • Mosquito
« Reply #11 on: April 28, 2015, 11:56:59 PM »
Once you have created the PDF file it is easy to create the TIFF from within Adobe Acrobat.  Much better than within AutoCAD.
