Author Topic: fractions fixed, units changed?  (Read 7163 times)
Bethrine
« on: April 16, 2015, 01:34:31 PM »
Okay, my units looked like the first picture (good)
I fixed my fractions how I want them to appear using the fraction dialog box and now my units look like picture #2 (bad).  :hahanot:
WHY?!?! And how do I fix it?
My assumption is that when I changed the fraction style, something automatically changed the units style along with it?
<EDIT: Corrected pictures.>
« Last Edit: April 16, 2015, 01:39:59 PM by Bethrine »
Re: fractions fixed, units changed?
« Reply #1 on: April 16, 2015, 01:40:33 PM »
post something with that dimstyle in it
Bethrine
« Reply #2 on: April 16, 2015, 01:42:28 PM »
This looks right...
« Reply #3 on: April 16, 2015, 02:11:34 PM »
so is it 'fixed' or do we get to see a drawing
« Reply #4 on: April 16, 2015, 02:21:48 PM »
Looks like your "Round Off" needs to be "0000"
Or did I miss the point?
Rob...
« Reply #5 on: April 16, 2015, 02:24:19 PM »
Are you referring to the 0'? If so, then check off the leading zero suppression box.
CAD Tech
« Reply #6 on: April 16, 2015, 03:09:51 PM »
I like to get rid of leading and trailing zeros...
Bethrine
« Reply #7 on: April 16, 2015, 04:23:26 PM »
That was it.  :-)
I clicked undo until I found it. Don't know why it would have changed when I unstacked the fractions though.
« Reply #8 on: April 16, 2015, 04:25:55 PM »
That was it.  :-)
Future...suggest making a NEW dimstyle based on one you want to edit....when it works duplicate settings to the original/delete or rename
Bethrine
« Reply #9 on: April 16, 2015, 07:00:11 PM »
I am doing something wrong, I have created dimstyles and thought I saved them, but when I open a new drawing, they are not there. How exactly would I do that? (A really good tutorial would be fine).
Rob...
« Reply #10 on: April 17, 2015, 07:06:23 AM »
You need to save them in your template file.
Open the template. Import the styles with design center. Save as Drawing Template.
Are you familiar with how to set-up a template and make it your default?
CAD Tech
« Reply #11 on: April 17, 2015, 08:45:00 AM »
Bethrine
« Reply #12 on: April 17, 2015, 10:00:10 AM »
I've played with it a bit but haven't taken the time to really set it up right. My official answer is no.  :no:
Rob...
« Reply #13 on: April 17, 2015, 10:03:03 AM »
It's easy. Once you get it, you'll wonder why you aren't using it yet. The information in this thread should be enough to get you going.
CAD Tech
Bethrine
« Reply #14 on: April 17, 2015, 10:06:12 AM »
Not sure on this...Is there a setting that changes the output from inches to feet and inches? I think that may be what happened? i.e.: 27" or 2'-3"
Okay, spending some time on this this morning.
