Author Topic: C++ programming in AutoCAD  (Read 7973 times)
bfred805
« on: April 14, 2015, 09:24:36 PM »
Is there a place for C++ is the world of AutoCAD programming? Has anyone heard of some APIs that make CAD even more efficient for them?
MickD
Re: C++ programming in AutoCAD
« Reply #1 on: April 14, 2015, 11:21:36 PM »
Are you familiar with ObjectARX?
Apart from custom objects or if you are processing say a point cloud with a million points I really can't see a good reason to use it now that there are .Net wrappers over pretty much the whole ObjectARX C/C++ API. Productivity with the .Net wrappers and .Net framework wins hands down.
Even with the performance of the point cloud example we're only talking seconds or less, not minutes.
- John Carmack
- J.R.R. Tolkien
ChrisCarlson
« Reply #2 on: April 15, 2015, 08:02:01 AM »
From what I understand the only supported languages from AutoDesk going forward is C#/VB .net. Which make sense especially since Microsoft is working on making .net universal across operating systems.
http://www.infoworld.com/article/2899136/microsoft-net/microsoft-open-sources-net-build-system.html
dgorsman
« Reply #3 on: April 15, 2015, 10:21:34 AM »
Source?
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
ChrisCarlson
« Reply #4 on: April 15, 2015, 12:16:24 PM »
dgorsman
« Reply #5 on: April 15, 2015, 02:52:41 PM »
Ah.  That's the managed dotNET reference so there wouldn't be a reference to anything else other than C#/VB.  ObjectARX is C++ and that's still supported.  Implying that everything else will be discontinued is not supportable.
This is where rumors get started...   :tickedoff:
try {GreatPower;}
   finally
      {MasterBasics;}
